Triodes that would like a 10K a-a OPT?
Old 21st October 2007, 10:32 PM   #1
sorenj07 is offline sorenj07  Germany
sorenj07's Avatar
Default Triodes that would like a 10K a-a OPT?
Are there any reasonable (price, availability) power triodes that would like a reasonably high primary impedance on such a transformer? I'd been thinking maybe the 6S19P but am open to other options such as a 6EM7 and 6BL7, though 6BL7's seem a little rare...
Old 21st October 2007, 11:28 PM   #2
Eli Duttman is offline Eli Duttman  United States
Triode wired 6V6s and close relations love 10 K trafos. See Poindexter's "Musical Machine".
Eli D.
Old 22nd October 2007, 12:51 AM   #3
sorenj07's Avatar
I might have to do the Musical Machine. I'd probably use some 5V6 tubes.
As for the driver tube: what would be best? The closest substitute I can think of is a 6N7S in that it has a similar gain (35 vs 47), but the 6N7S has a plate resistance of 11K versus 6.7K for the 5865. Is this likely to be an issue?
Old 22nd October 2007, 01:18 AM   #4
The twin triode is a 5965. High gm is a consideration in a differential splitter. I think that rules the 6N7 out. Of late, Poinz has been experimenting with hand matched 6GK5s in the splitter.
BTW, "El Cheapo" owes much to Poinz's design. We went for a much lower price point. Please notice that, like the 5965, the 12AT7 is a high gm type.
Eli D.
Old 22nd October 2007, 05:36 AM   #5
sorenj07's Avatar
Thanks! I think I'll actually go with 6S19P's, they offer the best price/power ratio for triodes I've seen. I've also been confirmed in my suspicion that 10K a-a actually is reasonable. If you draw the load line you'll see what I mean.
The OPT, without voltage measurements yet.
Old 22nd October 2007, 08:18 AM   #6
sorenj07's Avatar
I might try triode-wired 6AG7's. Looking at the datasheet for the Russian equivalent, the 6P9, things seem pretty hopeful. A 6N23P/6N1P driver stage Musical Machine-style with a negative long-tail supply seems like it should work fine, with a bit of headroom for feedback. And, if I hate the way the amp sounds after tweaking it constantly, I can always turn it into a real Musical Machine by subbing in 6V6's and a 5965.
http://tubedata.tigahost.com/tubedat.../113/6/6P9.pdf
Old 22nd October 2007, 08:12 PM   #7
sorenj07's Avatar
Update! Measured the various impedances of one of the OPT's (I assume it holds true for both) and got some interesting numbers.
I guess it's "Triodes that would like a 7.5K a-a OPT?" now
Triodes that would like a 10K a-a OPT?Hide this!Advertise here!
FS: two new 811 triodes Tekko Swap Meet 0 17th November 2008 12:27 PM
More triodes kmaier Tubes / Valves 4 4th July 2008 10:22 PM
LPT with low triodes? Fuling Tubes / Valves 9 5th December 2006 12:48 AM
FS: 50CA10 triodes ReinoutdV Swap Meet 6 5th September 2006 04:20 AM
Copyright ©1999-2017 diyAudio
