Old 7th January 2013, 12:55 PM   #191
data is offline data  Australia
Barbie, Isn't that one on the right the other way round?
Or am I looking at the traces wrong....
Old 7th January 2013, 12:56 PM   #192
Originally Posted by data View Post
You will be able to see the way they need to go by looking at the circuit before and after each cap.
Each output end will lead to the interconnecting wires from the pre amp PCB to the power PCB.
Thanks that's useful to know, will make sure the writing on the caps ends in the direction of those wire connectors. Many thanks
Old 7th January 2013, 12:57 PM   #193
Yes and I was just about to mention this to you, wow, I would have put that one the wrong way.....
Old 7th January 2013, 01:01 PM   #194
I'm not sure how much worse it would sound if you did get them around the wrong way, It's just that they are said to sound better with the foil end of the cap at the output, this is normally indicated by the direction of the writing, in the end that the writing starts, and out the foil end where the writing ends.
As I understand it anyway, unless i have it *** about.
Old 7th January 2013, 01:15 PM   #195
About to order the caps when I realised I've got a tiny little D class amp not used in years in need of caps - it hasn't got any ! Any idea what value I should get please, then I may as well order all at the same time
Old 7th January 2013, 01:19 PM   #196
Sorry, you would need to refer to the makers literature for the board/build, as I can't see anything in that pic.
I can't identify any positions where caps are needed?
Apart from the two electrolytic caps, they all look like surface mount caps, indicated with the "C" prefix on the PCB like all those near the output.
Old 7th January 2013, 01:29 PM   #197
They simply go on the channel imputes on the left between the RCAs and the amp
Old 7th January 2013, 01:33 PM   #198
Sorry, I'm not much help with that one.
Old 7th January 2013, 02:43 PM   #199
jkorten is offline jkorten  United States
You would put the capacitor right where your DC supply voltage comes in (screw terminals at the upper left in this picture I think). There appears to be only one voltage for this circuit so you'd need only one cap. Try a 0.1UF at 2X your rated supply voltage (typically 18V for these D amps).
Old 7th January 2013, 03:56 PM   #200
Thanks, so I just get the same as for the 10L amp <Clarity Cap ESA 0.1uf/630v> and one for each channel as its a stereo amp
Help and your input on YAQIN MC10L EL34 kalinga Tubes / Valves 6 27th January 2011 08:39 PM
Yaqin MC10L and KT88 megalodementia Tubes / Valves 21 15th January 2011 01:51 PM
MC10L is good or not iao Tubes / Valves 5 14th August 2010 11:22 AM
Yaqin mc10l &quot;popping&quot; Reg Stir Tubes / Valves 5 5th August 2008 04:43 PM
Yaqin MC-10L cruzrman Tubes / Valves 0 23rd July 2008 02:37 AM
Copyright ©1999-2013 diyAudio
