Yaqin mc10L - Page 16 - diyAudio
Old 29th January 2012, 04:42 AM   #151
data is offline data  Australia
A 510r 3w resistor is a good value, 270r 2w minimum for strapping. A lot of folk use something like a 100r 1w, but that's not safe as far as I have been taught.
Remove the UL connection and insulate well and tie back in a safe position, sever GNF. I just snipped out the cap & resistor in the GNF line of each channel that live on the pre board.
Old 29th January 2012, 09:31 PM   #152
How does the plate resistance of a triode strapped El34 compare to a true triode like the 300B? What sort of damping factor can you maintain with the NF removed? Sorry for the newb q's, I have a 20L and they're somewhat similar. I'm just starting to learn a bit about tube circuits.
Old 29th January 2012, 09:57 PM   #153
The Yaqin MC-20L is switchable between UL and Triode mode, as you know, whether the switching also switches out the GNF I have no idea, but in such a mode the GNF is not needed, and without it reduces distortion considerably.
Sorry but I'm not sure on the damping factor differences, and haven't the time to look into it, all I know is the MC-10L when triode strapped sounded much cleaner once the GNF was removed.
Old 29th January 2012, 11:33 PM   #154
I actually never use it in triode mode, ultralinear seems to have a little fuller midrange. Playing around with the GNF sounds interesting, though I am concerned about any impact on the bottom end. This amp is already a bit on the bright side and I'd hate to lose any bass.
Old 30th January 2012, 12:07 AM   #155
frugal-phile(tm)
planet10's Avatar
Which is better is very speaker dependent
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th January 2012, 12:48 AM   #156
I've heard that of SET amps, but not PP, is there a reason? Here's my 20L setup: MS-20L
It's driving Paradigm monitor 7's.
Old 30th January 2012, 12:57 AM   #157
frugal-phile(tm)
planet10's Avatar
Your speaker has XOs and likely an ugly impedance curve so it will likely be best with Pentode & feedback
dave
Old 30th January 2012, 03:06 AM   #158
I wouldn't sever the GFB on that amp unless you fix it in Triode, but you could reduce it, the GNF on the MC-10L was high.
And from what Dave has said about those speakers they are a load , so best to run it as you are in UL. An I see what Dave means, with the curve where the port takes over....
Old 30th January 2012, 05:12 AM   #159
Still, a nice speaker all the same.
Many speakers have pretty wild swings much worse than those Paradigm's, and a lot of manufacturers don't publish the real data.
Old 31st January 2012, 11:06 PM   #160
Did a little more digging about the damping factor of triode strapped El34's and I found an article by Menno Van Der Veen where he listed a comparison of various circuit types using El34's w/o GNF. In ultralinear, the circuit had a DF of 0.315. In triode mode it had a DF of 0.948 (both are w/o GNF). Does a DF of just under one mean the bass will be sloppy? Well, I found another article that compared the bass note decay time between various DF values. The difference in decay between DF>2000 and DF=1 is about 0.03 seconds. 3/100's of a second! I don't think that is even audible...at least not by me. So this has gotten me more interested in removing the GNF from the triode mode on my amp. I think I'll investigate adding a switch to turn off GNF for triode mode.
There were some old amps that had adjustable DF...do you think they did this by varying the GNF? Could one add a pot in place of the resistor to make GNF adjustable?
Help and your input on YAQIN MC10L EL34 kalinga Tubes / Valves 6 27th January 2011 08:39 PM
Yaqin MC10L and KT88 megalodementia Tubes / Valves 21 15th January 2011 01:51 PM
MC10L is good or not iao Tubes / Valves 5 14th August 2010 11:22 AM
Yaqin mc10l "popping" Reg Stir Tubes / Valves 5 5th August 2008 04:43 PM
Yaqin MC-10L cruzrman Tubes / Valves 0 23rd July 2008 02:37 AM
Copyright 1999-2017 diyAudio
