diyAudio Sponsor
Old 20th October 2007, 10:06 PM   #1
soundbadger's Avatar
Question mu followers --- current --- please help
i have designed a mu follower circuit based on the one in morgan jones valve amps book,,, just wondering what the current drawn by a mu follower is.. also how do i work out what power rating resistors to use ,,
cheers
soundbadger
Old 20th October 2007, 11:21 PM   #2
Miles Prower's Avatar
Ina word, Loadlines (See under "Technocal Reports"; he has a five-parter that tells all about it.)
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 21st October 2007, 01:09 AM   #3
diyAudio Moderator Emeritus
ray_moth's Avatar
Miles's link didn't work for me but I think he meant that the operating point needs to be chosen according the the plate curves. The load line itself will be almost horizontal b ecause of the high impedance that the mu-follower provides as a plate load to the lower tube. However, you still need to select an operating current based on the tube's characteristics. A rule-of-thumb approach is probably good enough here, i.e. use a high enough current for linear performance but don't go for too much plate dissipation.
Old 21st October 2007, 03:54 PM   #4
pftrvlr is offline pftrvlr  United States
I am building one mu-follower as headphone amp - with extra 6bx7 output cf stage. I use SPICE to set the operating point and check component power rating. Works fine for me.
Old 21st October 2007, 04:39 PM   #5
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Speaking of Spice. Soundbadger, your icon looks like it's from circuitmaker. I use the student edition which I got while in school. If that is what you have, I figured out to alter the model folder so that you can add more tubes to the library. I'll let you in on the trick if that's what you use.
Old 24th October 2007, 07:46 AM   #6
ive not used spice before, at college we use ewb multisim which is a bit limited. i just got a copy of pspice so ill see how i get on. i
Feedback and mu-followers mark_titano Tubes / Valves 2 14th August 2005 09:51 AM
Mu Followers -- ressources? Onvinyl Tubes / Valves 3 3rd March 2005 01:34 PM
beta followers baggystevo82 Tubes / Valves 16 23rd June 2004 12:05 AM
Zen-V with followers nobody special Pass Labs 23 20th July 2003 07:24 PM
Page generated in 0.07770 seconds (72.37% PHP - 27.63% MySQL) with 10 queries
