2 output transformers in 1 amp?
Old 11th February 2003, 10:14 PM   #1
PeteMcK is offline PeteMcK
Default 2 output transformers in 1 amp?
This may be silly, but here goes....
Is it possible to use 2 separate output transformers at the output of a push-pull amp, 1 on either side of the HT centre tap?
I'm thinking of converting a small stereo amp with single ended output stages to a more powerful mono amp
(guitar use, so linearity isn't that important)
Pete McK
Old 12th February 2003, 12:42 AM   #2
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Yep, secondaries in parallel so the trannies share the flux, I think...
You can probably even go class AB (be sure your OPTs are rated for max DC current), I'm not sure.
Tim
Old 12th February 2003, 12:47 AM   #3
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default // TRANNIES.
On the primary side the current is divided over the 2 windings,the secondary is combined in a // way so that the 2 16 Ohm windings give a 8 Ohm output and so on.
Should work.
Frank
2 output transformers in 1 amp?Hide this!Advertise here!
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
2a3 output transformers.... button_fly Tubes / Valves 3 10th October 2007 02:05 PM
Output Transformers eduardio Tubes / Valves 2 13th May 2005 02:42 PM
Using output transformers on Zen Amp? G Pass Labs 14 5th November 2004 11:54 PM
