| diyAudio Sponsor | ||
hi,
who makes low powered OTLs like 5 to 10 watts single ended ? eric |
#2 |
Transcendent Sound sells a kit for an 1,5W SE OTL with 4 x 6C19 output triodes per channel.
#3 |
Single ended really isn't the best choice for OTL. You have to make compromises which really outweigh any benefit the SE would otherwise give you. At least consider a class A push pull. You could get 5wrms out of a pair of 6c33c's class A
#4 |
who sells 'em fully built, Jeb ? hands are only good for computers.
#5 |
Oh, your looking to buy not build one.
| 40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? | dtm1962 | Solid State | 10 | 15th September 2011 07:38 PM |
| WTB: Transcendent OTLs | Studley | Swap Meet | 0 | 30th October 2008 08:53 PM |
| Variac to power-up Beveridge OTLs? | david yost | Tubes / Valves | 1 | 16th September 2007 06:11 PM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 05:49 PM |
| Page generated in 0.08441 seconds (77.48% PHP - 22.52% MySQL) with 10 queries |
