| diyAudio Sponsor | ||
#11 |
I'm trying to be proactive
#12 |
Does this look right? I'm not sure about all of the values; I just tried to get them close. I'm assuming the resister at the end is support to represent the load of the rest of the circuit? What are the B+1, B+2 suppose to be? Thanks for helping me work this out.
#13 |
The PSUD2 model above is a full-wave rectifier. Selelect Voltage Doubler instead (or simulate with half-vave for 1/2 of the voltage).
I suggest large first C for max voltage and minumum ripple. Use an additional RC filter if necessary to get the ripple down to a mV or so. To squeze the last volt out of the circuit use Shotkey diodes. Svein. |
#14 |
I'm working on 2 things, the changes Ian recomended for the PS and the voltage doubler. Thanks for the advice on the cap value and diodes. I'll model the voltage doubler later today.
| Quick Amp Question | audiobahnkid592 | Car Audio | 5 | 12th November 2007 07:11 PM |
| Quick quick question ! | guitvinny | Pass Labs | 6 | 7th February 2007 05:20 PM |
| Quick PCB question | Piper | Chip Amps | 2 | 7th March 2005 11:59 AM |
| VERY quick question... | Wyloch | Multi-Way | 2 | 3rd March 2005 05:34 PM |
| Page generated in 0.07513 seconds (74.10% PHP - 25.90% MySQL) with 11 queries |
