Point-to-Point, Pointers - Page 3 - diyAudio
Old 20th October 2007, 06:51 AM   #21
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Jonathan,
I searched point-to-point before and that's all that came up was vs. PCB stuff. Interesting reads, but it wasn't really helpful as far as tips for doing good P2P wiring.
Old 20th October 2007, 07:35 AM   #22
Yeh. Fair enough. I'd be interested in any results you get. If I get to "The Big City" one day I'll see if a uni' library has magazines with DIY stuff going back to the '60's where they actually spell this sort of material out for newcomers to the valve scene. For instance the UK "Wireless World" from that era would be a start and I imagine "Audio" in the States is another. Here in Oz we have a good local one so I might make that a holiday project in the new year. Just takes time...... Jonathan
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 20th October 2007, 09:09 AM   #23
Shoog's Avatar
Apply a logical approach to layout.
Even if it doesn't look beautiful - if your logical - it will still sound beautiful.
My PP builds still look like rats nests (though they are getting better), but I now rarely have any issues with hum or oscillation and I run a sensitive system.
Shoog
Old 20th October 2007, 09:28 AM   #24
Gordy is offline Gordy  United Kingdom
Originally posted by rwellerson
Hi all,
Well I do my "P to P" boards this way, as shown below: there is a lot of tinkering, ultra high patience on this but in the end the results are fine.
No noises, no hum and optimum strength for all supported components.
And excellent sound.
I use a 2mm fenolite board (with tag strips) just below the amp's top plate.
The board is supported on aluminum L shapes fixed to sides/front of the chassis.
You can see many other details and projects at:
http://vacuumtuberesearch.multiply.com/
[ ]s
Ricardo
Ricardo, your work looks excellent.
And now an example of the wrong way: (about half way down the page) http://www.6moons.com/audioreviews/s...lcabernet.html
Old 20th October 2007, 10:15 AM   #25
soundbrigade's Avatar
Send a message via MSN to soundbrigade
I will use enamelled Cu-wire as it is stiff makes nice 90 degree bends and keeps components approx where I left them.
An advice I got from Russian friends was to cover all solder joints and exposed metal wire with shellack.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 20th October 2007, 10:39 AM   #26
Sensible advice: http://www.aikenamps.com/PCBorPTP.htm
Wire Wrap connections for point to point mashaffer Tubes / Valves 10 7th July 2007 02:11 PM
Benifits of point to point wiring for digital circuit? MGH Digital Source 15 14th September 2006 11:17 PM
Anyone use magnet wire for point to point wiring projects? Hybrid fourdoor Parts 10 2nd February 2004 09:11 AM
Audio Note's Kit One done in point-to-point wiring Wram Tubes / Valves 18 29th April 2003 11:59 PM
Point to point crossover soldering Ilianh Multi-Way 9 24th December 2002 05:14 AM
Copyright 1999-2017 diyAudio
