Point-to-Point, Pointers - Page 2 - diyAudio
Old 19th October 2007, 06:52 PM   #11
49 - for the 19th time!!!
c2cthomas's Avatar
Hi Jeb,
Take a look at this site - lots of projects and photo's.
http://www.pmillett.com/index.html
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 19th October 2007, 07:05 PM   #12
Gordy is offline Gordy  United Kingdom
It's all about planning...
Step 1
Think about it.
Step 2
Plan it in your mind.
Step 3
Scribble it out on paper.
Step 5
Mock it up.
Step 6
Rest and relax. Drink a nice cup of tea (/ coffee / beer). Cuddle the wife. Kick the cat. (Or cuddle the cat and kick the wife...). Etc.
Step 7
Repeat steps 1 to 5 about a half-dozen times before you even touch the toolbox...
Old 19th October 2007, 07:35 PM   #13
Steve Eddy's Avatar
Step 1
Think about it.
Step 2
Step 3
Step 5
Mock it up.
Step 6
Step 7
Very good advice! Click the image to open in full size.
se
Old 19th October 2007, 09:29 PM   #14
unclejed613's Avatar
i once had a job where we built test fixtures and prototypes, and had to learn how to make wiring harnesses, and make them neat (including keeping the same wires in the same place in the bundle all the way through). we used waxed nylon lacing cord, not zip ties. it takes a bit of practice, but once you get the hang of it, you can do it quickly and easily. the best knot to use is a clove hitch, topped with a surgeon's knot. put your ties about 1" apart, and keep your wires straight in the bundle. there's no books on the subject, as far as i know, but you can see examples of it in military surplus equipment. you may not want to go that far for neatness, but it's not difficult to do. you can even prefab the wiring harnesses on a piece of wood with nails in it (laid out as a duplicate of the inside of the amp chassis, with the nails in the same places as the terminals on the tie strips), which saves a lot of time if you end up making more than one amp.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 19th October 2007, 09:50 PM   #15
From time to time I've seen the following expression in DIY articles in magazines especially those involving high impedence circuits. The author will advice the constructor to; "minimize stray capacitance". In practise what does this mean for us when laying out circuitry. i.e. what precautions do we take.
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 20th October 2007, 12:15 AM   #16
rwellerson's Avatar
Hi all,
Well I do my "P to P" boards this way, as shown below: there is a lot of tinkering, ultra high patience on this but in the end the results are fine.
No noises, no hum and optimum strength for all supported components.
And excellent sound.
I use a 2mm fenolite board (with tag strips) just below the amp's top plate.
The board is supported on aluminum L shapes fixed to sides/front of the chassis.
You can see many other details and projects at:
http://vacuumtuberesearch.multiply.com/
[ ]s
Ricardo
Old 20th October 2007, 12:52 AM   #17
Steve Eddy's Avatar
Beautiful work! It really illustrates Gordy's advice.
Hope you don't mind that I copied the image and loaded it on my server. Wasn't able to link it directly to the image on your end.
se
Old 20th October 2007, 02:44 AM   #18
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Wow, that's a masterpiece!
Old 20th October 2007, 04:02 AM   #19
mod_evil's Avatar
Send a message via MSN to mod_evil
I have a name to this:
Brazilian Patience to beautiful works.
Best Regards,
Felipe Navarro
Old 20th October 2007, 05:11 AM   #20
Hi Jeb-D I tried "point to point wiring" in Google and got several sites. I recall some years ago seeing a site with about 15 pages on the tpoic. Can't remember where though.
Try "point to point versus PCB" in Google too. That yields some results.
Wire Wrap connections for point to point mashaffer Tubes / Valves 10 7th July 2007 01:11 PM
Benifits of point to point wiring for digital circuit? MGH Digital Source 15 14th September 2006 10:17 PM
Anyone use magnet wire for point to point wiring projects? Hybrid fourdoor Parts 10 2nd February 2004 08:11 AM
Audio Note's Kit One done in point-to-point wiring Wram Tubes / Valves 18 29th April 2003 10:59 PM
Point to point crossover soldering Ilianh Multi-Way 9 24th December 2002 04:14 AM
Copyright 1999-2017 diyAudio
