KT88 Minimum Mounting Distance
Old 21st October 2007, 11:19 PM   #11
gingertube is offline gingertube  Australia
Rob,
I checked on the w/e. The above is right. More particularly, when mounting tubes vertically. pins 4 and 8 should lie on the line through the tube centres.
If mounting tubes horizontally then pins 2 and 6 should lie on the line between tube centres.
Ian
Old 22nd October 2007, 12:17 AM   #12
Rob11966 is offline Rob11966  Australia
Rob11966's Avatar
Hi Ian,
This sounds important to me but I am not quit6e sure that I understand. I am mounting the tubes vertically and in a line next to each other. Am I correct in assuming that the tubes are mounted so that pins 4 and 8 run along this line so that looking from left to right the tubes would be mounted in such a way that looking from the front, the far left side of each tube would be pin 4 and the far right would be pin 8 and that this arrangement would direct most of the radiated heat forwards and backwards?
Rob
Old 22nd October 2007, 12:44 AM   #13
Rob,
Yep. thats it.
Ian
KT88 Minimum Mounting DistanceHide this!Advertise here!
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 10:52 PM
DSP XO > Minimum Phase? amo Multi-Way 8 19th October 2003 08:33 AM
Any minimum distance from driver to port? Circlotron Multi-Way 4 27th December 2002 11:23 PM
