diyAudio Sponsor
Old 11th February 2003, 11:36 AM   #1
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Parallel feed OT
Hi All,
I am considering building something like Kandaudio's SE parafeed preamp. But don't want to order the Lundahl, because I want to see if my tranny builder can build me something like that.
So what do I have to ask for.. in the case of say a 6n1p tube..paralleled both sections Ra of 2200ohm..so do I ask for a 7k SE transformer that does not have to pass a single mA of DC?
Bas
Old 11th February 2003, 03:16 PM   #2
dhaen is offline dhaen  Europe
dhaen's Avatar
Hi Bas,
I believe that you are right with the transformer impedance and current specification.
The trouble will come in the way you supply DC to the anodes.
Are you going to use a choke? If so, then you must consider the choke's self capacitance and the transformer's self capacitance to be in parallel.
Old 11th February 2003, 03:19 PM   #3
Hi John,
I was thinking of using a CCS? (depletion mode MOSFET)
Does that make it easier? I suppose it.... does because a CCS has negligible capacitance compared to a choke...right?
Bas
Old 11th February 2003, 03:34 PM   #4
dhaen's Avatar
Hi Bas,
That sounds a nice idea. Capacitance is much less of a problem.
Can you get high voltage depletion mode fet's? I'm well out of touch
Great for self biasing - just like valves..
Old 11th February 2003, 03:36 PM   #5
316a is offline 316a  England
316a's Avatar
Default 6C41c
Hi Bas ,
CCS loading , to me means low Ra valves , run at high current , low anode volts . I find that CCS loading usually means ridiculous heat , my own MTP2P50E based mosfet sink ran at 70mA and got REALLY hot , and that was with a massive heatsink , and not really dissipating as much as it should (I kept the B+ within safe limits) . Why not try something like stacked 6C41c in an SRPP / SEPP arrangement with fixed bias to the lower valve ? It would be cheap to build , only the power supply needs to have higher HT than with choke loading (400V+) . My usual advice regarding parafeed prototypes and toroids as output transformers applies , could make a nice , cheap project .
316a
Old 11th February 2003, 03:42 PM   #6
316a's Avatar
Default Ooops !
Sorry , you were mentioning pre-amps , my post was regarding power amps . Running a CCS load on a 6N1P should be a doddle , compared to what I went through developing my power CCsource !
316a
Old 11th February 2003, 03:42 PM   #7
Hi John,
I've never been in touch...but that is an entire different matter..
Yep K&K audio sells little kits..ha..ha if you can call it a kit!
3 parts...mosfet, pot, pcb..
It uses the DN2540N5 (400V)
HTTP://www.supertex.com/pdf/datasheets/DN2540.pdf
Bas
Old 11th February 2003, 03:48 PM   #8
Might very well still try that...I still have the little toroids lying about idly after the 6c45pi spud thing failed..
mmm, come to think of it..I have seen 6c33 preamps..maybe a 6c41c preamp is not even such a bad idea? Nah, 6s19 is wild enough..
Bas
Old 11th February 2003, 04:00 PM   #9
dhaen's Avatar
Default The sandman commeth
Hi Bas,
Nice FET
Almost as good as a valve
Old 11th February 2003, 04:10 PM   #10
How can you tell it is a nice piece of sand?
I just took Kevin's word for it.
Bas
6AS7 Parallel Feed Amp lcsegeng Tubes / Valves 7 9th August 2008 02:17 AM
Isolating parallel feed amplifiers neazoi Tubes / Valves 6 24th July 2008 10:51 AM
Adding a parallel feed on DRD eeyore Tubes / Valves 1 11th July 2007 04:57 AM
Parallel feed (choke load) in output stage yagoolar Tubes / Valves 27 17th March 2006 10:49 AM
Magnequest B7 parallel feed transformer for sale MiaTele52 Swap Meet 3 16th January 2006 03:42 AM
Page generated in 0.08588 seconds (87.18% PHP - 12.82% MySQL) with 10 queries
