Parallel feed OT - Page 3 - diyAudio
Old 12th February 2003, 01:28 PM   #21
diyAudio Senior Member
fdegrove's Avatar
Default LOADS.
Hi Bas,
What is a typical load that a preamplifier "sees" is that 47k?
For a MM phono stage that would be the standard input impedance in conjunction with say,100 to 150 pF capacitance to load the cartridge.
In my case..the power transformer input rca has a grid leak resistor of 47k..
Errr,do you mean a step up xformer for a MC cart.?
Frank
Old 12th February 2003, 01:31 PM   #22
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Frank,
Its a parafeed preamp...so I want an output transformer..parafeed coupled..
So I thought the load it sees would be the poweramp?
Bas
Old 12th February 2003, 01:36 PM   #23
fdegrove's Avatar
Default I SEE...
On the secondary side it will look at the input impedance of the amp + the cable's properties.
So,in order to drive all this properly the secondry side of your step down xformer should be an order of magnitude lower than the input impedance of the amp.
Often a value of 600 Ohm is chosen for this as this is the pro standard for balanced operation.
Frank
Old 12th February 2003, 01:46 PM   #24
Hi again and thanks again Frank. ;-)
Ok so as this is gonna be a preamp...
This is what I should tell my tranny builder.. :
1.) SE transformer
2.) The core may be fairly small...no DC and fairly small voltages. (Maybe around 1 watt max?)
3.)Output impedance 600ohm or lower?
4.) Primary or reflected impedance as high as possible without affecting hf response. (say should only drop of after 25kHz)
Bas
Old 12th February 2003, 01:56 PM   #25
fdegrove's Avatar
Default PARAFEED OPT.
1.) SE transformer
I'm pretty sure that the xformer builder we have in mind has done this before.
2)If it must be a parafed job than,yes.
3)Going lower than 600 Ohm will only add to the step down ratio,and degrade performance IMO.
4)Yes,something like 15K should be fine.Bandwidth as large as possible,I'd say.
Ciao,
Frank
Old 12th February 2003, 02:07 PM   #26
Oki Doki.
So Long, and Thanks For All The Fish
Bas
6AS7 Parallel Feed Amp lcsegeng Tubes / Valves 7 9th August 2008 02:17 AM
Isolating parallel feed amplifiers neazoi Tubes / Valves 6 24th July 2008 10:51 AM
Adding a parallel feed on DRD eeyore Tubes / Valves 1 11th July 2007 04:57 AM
Parallel feed (choke load) in output stage yagoolar Tubes / Valves 27 17th March 2006 10:49 AM
Magnequest B7 parallel feed transformer for sale MiaTele52 Swap Meet 3 16th January 2006 03:42 AM
Copyright 1999-2017 diyAudio
