diyAudio Sponsor
Old 17th October 2007, 09:01 PM   #1
Default Broskie OTL
Broskie posted this new otl circuite on the Tub Cad Journal.
I am assuming it is just the output stage and would need
a differential input. Has anyone here built this yet ? I wonder
what the output impedience would be assuming just the local
feedback used.
Old 18th October 2007, 05:18 AM   #2
The output impedance in Class A will be Rp/2*(1+µ) and in AB Rp/(1+µ) it is basically an ordinary inverted Futterman OTL.
Regards Hans
Broskie regulator oscillates rman Tubes / Valves 11 26th July 2009 04:35 AM
The Broskie Cathode Follower for a DAC bequerel Digital Source 5 25th September 2008 09:34 PM
broskie voltage regulator dave dove Tubes / Valves 2 14th January 2007 09:50 PM
John Broskie's enhanced T8 CarlyBoy Tubes / Valves 13 8th October 2006 06:13 PM
Where is John Broskie ? reinhard Tubes / Valves 7 8th October 2002 01:27 PM
Page generated in 0.06646 seconds (70.59% PHP - 29.41% MySQL) with 11 queries
