diyAudio Sponsor
Old 17th October 2007, 04:24 AM   #1
viagraless's Avatar
Default Vietnam tube amplifier festival
Hello everybody.
Recently, the DIY tubey movement in Vietnam become stronger than ever, with the advantage with huge stock/tube military source available since Vietnam war.
Last September, the 2nd festival for Viet tubey have been held at Hochiminh city with more than 200 visiteors as well as 15 big amplifiers from whole country. Fyi, because the requirement for participation is DIY amplifier stronger than 15W, therefore we funny named the festival is "Sumo contest"
Below is some snaps we would like to share :
Some time could supply the "hot" things
Old 17th October 2007, 04:25 AM   #2
viagraless's Avatar
Fifteen athletics from the country
Old 17th October 2007, 04:26 AM   #3
viagraless's Avatar
Some samples of nice amplifiers attended :
OTL amplifier using 20 tubes 6H13C
Old 17th October 2007, 04:29 AM   #4
viagraless's Avatar
845 Single ended, using Tango OPT
Old 17th October 2007, 04:30 AM   #5
viagraless's Avatar
211 RCA push-pull, Audionote OPT
Old 17th October 2007, 04:32 AM   #6
viagraless's Avatar
813 mono block
Old 17th October 2007, 04:33 AM   #7
viagraless's Avatar
833 Single ended.
Old 17th October 2007, 04:39 AM   #8
viagraless's Avatar
All apmlifier have been tested the specification .
Volume level also fixed to ensure the sound from speakers are same.
The reference systems for blind test:
Speaker : JBL 4344 monitor
CDP : Teac 50
Old 17th October 2007, 04:41 AM   #9
viagraless's Avatar
The judge team consistes of pro-audiophile
Old 17th October 2007, 04:43 AM   #10
viagraless's Avatar
Now is the result :
833 Single end : best designer.
Tube SE amplifier with 6P3S (russian tube) danzup Tubes / Valves 46 12th April 2012 08:35 PM
Tubes in Vietnam Rodeodave Tubes / Valves 5 19th September 2006 06:06 AM
VietNam audiophile cd149dc Introductions 1 28th March 2006 06:17 PM
Welcome to Vietnam! Huaaahhhhhh! thanh Introductions 5 7th December 2004 09:15 AM
Page generated in 0.10035 seconds (77.80% PHP - 22.20% MySQL) with 11 queries
