diyAudio Sponsor
Old 16th October 2007, 08:11 PM   #1
whitelabrat's Avatar
Default triode pentodes
Just a wild musing of mine on a Tuesday afternoon.
Why not use the triode side of a triode-pentode TV tube by itself for a preamp application? For example something like a 6gh8 or 6kt8? Of course it would take two tubes to replace a single dual triode, but heck, you can often find a 5 pack of oldies for dirt on ebay (or my box o' funky toobs).
Old 16th October 2007, 08:28 PM   #2
Or along the same lines, how about using the pentode side as a triode?
And 12GN7's in a push-pull power output configuration?
Old 16th October 2007, 09:37 PM   #3
00940 is offline 00940  Belgium
have you seen this ? Audiovalve RKV schematic (hybrid headphones amp)
Ben.
Old 16th October 2007, 10:39 PM   #4
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
All tubes are excellent; why people forget about TV tubes is beyond me. Many have impressive transconductance and perveance!
The 6X8, a common-cathode monstrosity, is actually very similar to a 6J6 when the pentode is triode-strapped. This should come as no suprise, as the constructions are even the same. Even with the screen grid used as intended, it still makes an excellent LTP: an interesting alternative to a single triode or pentode input stage. The dissimilarity makes little difference, especially if you're only interested in one plate's output. Since you have two opposed grids, you can easily apply NFB, subtract signals or do even more interesting things, instead of using the low impedance cathode as NFB input, as is traditionally done.
The 6U8 (and many others like it) has independent triode and pentode sections, easily used in all the two-tube topologies: LTP, cascode, mu stage, SRPP and so on. The triode is roughly similar to a 12AT7.
Pay much attention to video pentodes. The 7KY6 is cheap and plentiful, yet has Gm ~ 20,000umhos! I've graphed its triode mode curves and they are excellent as well (I should do this again, gathering accurate data and actually plotting it for use). There are many tubes that combine a video pentode and a high perveance triode, something like a 6DJ8's triode, into one bottle. I could see this used as a high bandwidth driver and cathode follower for some insane driver stage.
And let's not forget those RF pentodes, either. The lowly 6AU6 was extremely popular in quality test equipment, where linearity is at least as stringent as the most discerning golden ear. Probably a quarter of the 6AU6's in my collection have Tektronix labels stuck on them. I also have a bunch of 6DK6s, probably for the same reason. All are high gain pentodes with excellent transconductance and, given the size, suprising current capacity. Don't like pentode? Triode strap them! Who needs a 6BX7 when you can push 20mA through one of those little bottles! Seven pin sockets are cheap, go nuts.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 16th October 2007, 11:43 PM   #5
Only thing might be microphony as compared to e.g. EF86 etc. But otherwise I share the amazement. I have for decades used ECF80, 6U8 etc. In a power amplifier I am fond of using those as first stage/concertina phase splitter. (Stabilisation of operating point can be enhanced by feeding G2 from next stage cathode.)
_______________________________________________-
Take care of the sense and the sounds will take care of themselves. (Lewis Carroll)
Old 17th October 2007, 06:40 AM   #6
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
'cept 1B3's, Tim.
Old 17th October 2007, 06:47 AM   #7
coresta is offline coresta  France
coresta's Avatar
and the EF184 / 6EJ7 , one
Old 17th October 2007, 07:46 AM   #8
Geek's Avatar
Big triode-pentodes have a good place too, ECL82 (6BM8) and ECL86 are great 1-watt-amp-in-a-bottle fellows.
Here's some 6X8 work Tim spoke of:
http://dogstar.dantimax.dk/tubestuf/paraph.htm
Spectacular tube, especially trioded
Here's some mini triode-pentode work and impressions I've done for guitar:
http://tonegeeks.sicomm.us/ToneGeeks/index.php?topic=56
Cheers!
Pentodes. bigwill Tubes / Valves 23 4th August 2009 02:14 AM
Beam pentodes and suppressor-grid pentodes of same type jon_010101 Tubes / Valves 3 2nd May 2009 11:18 PM
Pentodes, triode mode and grid screen dissipation 101 duderduderini Tubes / Valves 3 22nd September 2008 01:48 AM
Another 3f4 spice triode model: 5718 submini triode wa2ise Tubes / Valves 0 5th September 2008 04:31 AM
Curvecaptor with pentodes?? aletheian Tubes / Valves 0 30th March 2007 08:22 PM
Page generated in 0.10143 seconds (77.97% PHP - 22.03% MySQL) with 10 queries
