| diyAudio Sponsor | ||
My first post here, and my first DIY, dont be too hard on me...
I got bored, no euros to upgrade my system, so I started playing with my amplifier... 1. replaced all tubes with Siemens NOS... 2. removed uneccessary gadgets, inputs and selector, volume control, usage timmer, relays, etc... 3. removed global negative feedback 4. replaced 12AT7 with E80CC, replaced R28 on the power supply to cope with extra current of this babies, and removed cathode CAP to decrease gain further... 5. rewired input stage point-to-point with Allen-Bradley resistors and replaced WIMA coupling capacitors with Russian PIOs...
#2 |
Its seems a nice job . But good tube circuitry at are simplier with fewer components, and more solid state free the best .
Regards tugat |
#3 |
#4 | |
I did remove 20 components and 2 meters wire from the signal path, plus some not needed accessories... It looks fuller because of the size of the Russion PIOs... What else do you suggest, simple enough for me to do... ![]()
#5 |
Sorry i meant "good tube circuitry at best...".In my personal
experience , rectifying the filament supply of preamp and driver tubes is a good shoot . I like Black Gate electrolytics, Auricap props , and high voltage SiC Schottkys as rectifiers . Here , [urlhttp://www.tentlabs.com/Products/page6.html[/url] you can find more interesting matter to go further , as in my point of view an upgrade is never finnished . Tugat |
#6 |
#7 |
Modding/replacing/removing can be quite addicting and I agree with tugat on the simpler the better. But I think it's important to know when to stop. I've built an amp over a year ago and it's been modded so many times that it's now a completely different beast. The sad part of it is, I really not convinced that it sounds better than it did last year! Sound is so damned subjective!
~~~John~~~ |
#8 |
Lowrider .
Removing R6 did you left it open . No negative feedback ?! Doesn't it sound more distorted ? Maybe it was better to reduce the amount of feedback instead . |
#9 |
Hi Lowrider
It seams that exist an error in your schematic. R18 and R19 must be connected between the pin 8 of the EL34 ( cathode ) and ground. It is used to measure bias. Maybe the error is only in the schematic and not in the implementation... Welcome!!
Jorge |
#10 | |||
Maybe there is more distortion, but it sounds much better now, particularly, more real, more lively, nicer mids and highs... Quote:
Nice to meet you again, had to get into DIY for it... Maybe the schema is wrong, I didnt change anything there, if I have time, I will open it on the weekend and test how it is really connected...
| Problem with Classic 8.0b | Ree | Solid State | 1 | 8th August 2008 11:37 AM |
| need some classic tl advice | galac | Multi-Way | 8 | 23rd November 2007 09:52 PM |
| Classic BR Alignments | BAM | Multi-Way | 0 | 20th November 2005 04:31 PM |
| ARC Classic 60 circuit | hatasa | Tubes / Valves | 7 | 29th June 2002 03:11 PM |
| Page generated in 0.11747 seconds (81.97% PHP - 18.03% MySQL) with 10 queries |
