Classic 16.0 - Page 2 - diyAudio
Old 17th October 2007, 09:01 AM   #11
Lowrider's Avatar
Default Re: Classic 16.0
Originally posted by TugaTweaker
Sorry i meant "good tube circuitry at best...".In my personal
experience , rectifying the filament supply of preamp and driver tubes is a good shoot . I like Black Gate electrolytics, Auricap props , and high voltage SiC Schottkys as rectifiers . Here , [urlhttp://www.tentlabs.com/Products/page6.html[/url] you can find more interesting matter to go further , as in my point of view an upgrade is never finnished .
From your very interesting link:
Lowering the overall feedback is not interesting for all of you. Some speakers become 'fluffy' in the bass. If you consider lowering the feedback, I would suggest to perform audible experiments, because the effects become very apparant if things go wrong. For this purpose, I just apply a potmeter over the resistance, so that I can experiment very quickly. If the effect works for you, the result is a overall improvement of dynamics and imaging.
Old 17th October 2007, 09:34 AM   #12
Lowrider's Avatar
http://www.tentlabs.com/Products/Tub...ter/index.html
Interesting, but I need higher output current to be able to use existing connections...
Old 17th October 2007, 08:30 PM   #13
There are options to cope , two E80 plus two 6SN7 heaters, not a big current problem as you will see consulting specific tubedata . But you said nothing about the feedback mod . You removed R6 and C3 , any subsequent mod is unnefecttive then , unless you have connected the wire to the next component in the circuit .
Tugat
Old 18th October 2007, 06:40 AM   #14
Lowrider's Avatar
There are options to cope , two E80 plus two 6SN7 heaters, not a big current problem as you will see consulting specific tubedata . But you said nothing about the feedback mod . You removed R6 and C3 , any subsequent mod is ineffective then , unless you have connected the wire to the next component in the circuit .
Good morning,
I need 4 x .6 A = 2.4A, Tentalabs modules are 1.5A maximum, Machmat needs at least 10V input, my transformer tap is 6.3V, of course, what would you suggest...
Anyway, I dont hear any hum, even with my ear against the speaker, it was one more experiment...
I broke the global feedback loop, no global NFB in my amplifier now, also hardwired triode mode...
I know the majority use and recommend global NFB, I tried both options, and preferred the sound in my system without...
I am very sensitive to crossover distortion, only like first order, or none, maybe NFB has a similar effect on sound, besides the known benefits...
Old 20th October 2007, 08:33 AM   #15
Lowrider's Avatar
Tube_Dude,
Verified, and the schema corresponds to the circuit, 0 ohms between cathode, point 8, and ground, 10 ohms between supressor, point 1, and ground, or cathode, of course...
Maybe the Chinese do things different, but it works...
I replaced a couple more CAPs with Nichicons, aligned the PIOs on the right, and took a better picture, see first post...
The power supply schema is already updated with some more mods I am going to do next weekend, ordered a bunch of Philips 0.13 uF 1600V, to apply all over...
Old 21st October 2007, 03:38 PM   #16
Tube_Dude's Avatar
Originally posted by Lowrider
Tube_Dude,
Lowrider
Strange!
Let's see, try to put the switch for monitoring the bias to one output tube , and measure again the resistance in that tube.
Maybe the 10 Ohms resistor is only used for measurement purposes , and is shunted by the switch in normal conditions of operation.
Jorge
Old 21st October 2007, 04:07 PM   #17
Lowrider's Avatar
The switches are used one by one only measuring/adjusting bias, how could they shunt the resistor...
Old 21st October 2007, 04:13 PM   #18
Tube_Dude's Avatar
Try it!
With the amp disconnected , of curse !
Jorge
Old 21st October 2007, 04:16 PM   #19
Lowrider's Avatar
Next weekend I open it again to install all the bypass CAPs, I will try to do that, the problem is that I have to remove the EL34 to put it upside down, to open...
Old 21st October 2007, 04:30 PM   #20
Tube_Dude's Avatar
You don't need to open the amp to do that experience.
Take out one EL34, and measure the resistance between pin 8 and ground ( the outer part of the RCA inputs are a good ground).
Then , see if rotating the switch for that tube position , change the reading...
Jorge
Problem with Classic 8.0b Ree Solid State 1 8th August 2008 12:37 PM
need some classic tl advice galac Multi-Way 8 23rd November 2007 10:52 PM
Classic BR Alignments BAM Multi-Way 0 20th November 2005 05:31 PM
ARC Classic 60 circuit hatasa Tubes / Valves 7 29th June 2002 04:11 PM
Copyright 1999-2017 diyAudio
