diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Interstage X-former identification (http://www.diyaudio.com/forums/tubes-valves/110077-interstage-former-identification.html)
Klimon 14th October 2007 08:29 PM
Atleast that's what I think they are. I removed a pair of these EI60 size Philips transformers from valve studio gear. Below are the data of my measurements (every ounce of info I could extract using a simple multimeter):
-- Three primaries: DCR = 17ohms / 14ohms / 157ohms
-- Three secondaries: DCR = 1020ohms / 915 ct 1141 ohms
Impedance and turns ratio's are as follows (determined by applying ac and measuring):
Applying a voltage to one (no matter which) of the primaries gives a voltage seven times higher on each of the secondaries (no matter which)
--> imped. ratio 1:7 / turns ratio 1:2,6
--- Depending on which primaries I connect in series and in what order, these additional impedance // turn ratio's are available:
1:6 // 1:2.45
1:3.25 // 1:1.8
1:2.3 // 1:1.5
The last of these options seems fit for interstage duties. In this configuration primary inductance is 9Hy (measured with simple multimeter). Any educated guesses if these trafo's are air-gapped?
Applications I can imagine are SE--> SE interstage / SE --> PP interstage (phase-splitter) / both previous options but parafeed / PP --> PP interstage (doesn't seem very interesting).
Any thoughts about these things or applications would be welcome; for now I'm thinking of using them as phase-splitters driving 6080's in a shoog-style amp.
Thanx!
Simon
Resources saved on this page: MySQL 18.75%
