diyAudio Sponsor
Old 14th October 2007, 06:04 PM   #1
greg788 is offline greg788  United States
Default 6L6G and 6L6GB differences?
On paper the 6L6G and 6L6GB have identical specifications: 360 V plate rating, 19 watts and a screen rating of 270 volts and 2.5 watts
Here's the question: in a fixed (cathode) bias amplifier can I really use a 6L6G instead of a 6L6GB? Or are there other specs. I'm not seeing that make the earlier 6L6G not robust enough?
My Leben CS-600 amplifier is fixed (cathode) bias. It has two toggle switches to vary plate voltage and cathode bias. With these switches it can run a bunch of output tubes (EL34, 350B, EL37, 6L6GB, 6L6GC, KT66, etc.)
The owner's manual lists the 6L6GB as OK to use but NOT the earlier GA or G. The GB's are run at 410 V plate voltage and 680 ohms cathode resistance.
Word on the street is that the earlier 6L6G sounds better than the 6L6GB (and are still pretty cheap NOS), hence my interest.
Old 14th October 2007, 06:16 PM   #2
richwalters's Avatar
Have a look at http://frank.pocnet.net/
richj
Old 17th October 2007, 01:09 AM   #3
The only difference is in the tube size/shape. The innards are the same. The 6L6GB came later and the reduced size was an advantage for amplifiers getting smaller.
________________________________________________--
Look after the sense and the sounds will look after themselves. (Lewis Carroll)
Differences between X0 and X0.2 rsbay Pass Labs 2 27th March 2010 04:40 PM
experimental 6L6G / 6BG6G amp design brainstorm chromal Tubes / Valves 34 21st March 2009 12:45 AM
FS: Quad Sylvania 6L6GB Zedguy Swap Meet 2 10th February 2008 01:01 AM
6L6G Amp recommendations 77seriesIII Tubes / Valves 13 21st November 2007 04:42 PM
What is the differences between Richard Moon Multi-Way 2 23rd September 2002 01:46 PM
Page generated in 0.07234 seconds (74.22% PHP - 25.78% MySQL) with 10 queries
