7 pin X
7 pin X
Old 14th October 2007, 02:21 PM   #1
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
7 pin X
Default 7 pin X
Does anybody know the type of the 7 pin mini tube in the attached picture? I found 4. Maybe they are useful for audio. There is a screen with a stamped X rib between the 2 constructions in the tube.
Old 14th October 2007, 03:16 PM   #2
JohnAtwood is offline JohnAtwood  United States
JohnAtwood's Avatar
Default 7-pin tube
This looks almost for sure a 6AL5 dual diode (or possibly a 12AL5, the 12V version). This is sometimes used as a bias supply rectifier, but is more often used as a detector in FM tubers and TVs. Many classic tube tuners from the 1950s and 60s used these.
- John Atwood
Old 14th October 2007, 04:01 PM   #3
kevinkr's Avatar
7 pin X
Looks like a 6AL5 dual diode to me as well. Sometimes used in FM ratio detectors or discriminators. Some people have also used them as bias and very low voltage/current full wave rectifiers.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 14th October 2007, 04:05 PM   #4
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
I'm thirding 6AL5
Old 14th October 2007, 06:47 PM   #5
gianis is offline gianis  Greece
Default 6al5
may be 6al5 dedector
Old 14th October 2007, 09:33 PM   #6
Salas's Avatar
7 pin X
Thanks guys. Bias rectifier...hmmm, I got some 2A3 RCA by Volterex, and I think of making a PP 2A3 in the future. Should not be bad to use fix bias 2A3s driving a 6K6 PP OP, and use the mini rectifiers for a regulated bias circuit with a 12B4 pass and a 12AX7 controller. Maybe LTP input EF86 to 2A3 I am thinking. On the other hand...maybe too low 2nd harmonic vs 3rd, 5th etc. Have you listened to an excellent 2A3 PP circuit that you can recommend?
7 pin XHide this!Advertise here!
Copyright ©1999-2017 diyAudio
