| diyAudio Sponsor | ||
Hi Friends,
I have a good xformer with a 390+390v 300mA to supply TWO 6L6's in PP. The unique problem is this: I like ajustable bias but the xformer haven't a tap to low voltage bias ( +- 40v ) How can I take this voltage from one tap of 390v? How I do this? Can anybody help me? Best Regards, Felipe
Brazilian Tube Amp Builder. |
#2 |
Can you sacrifice 35V from 390V?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
#4 |
If you look at some guitar amp schematics, they derive the bias from tapping right off the HV. They put a resistor in series with on the AC side of the rectifier diode, rectify 1/2 wave and have a load R immediately after the diode as well as the bias pot for load. This keeps surges down to a manageable level. If your amp runs class A or AB1, you can have a total current through the V- supply of 5mA or less. If it runs A2, AB2 or B, you should use either a proper tap or a transformer setup like Fred's circuit above. Shaver isolation transformers work really nice for this Cheers! |
#5 |
There are a couple interesting ideas here: http://www.aikenamps.com/BackBiasing.html
#6 |
Hi Friends,
I think it's very danger retifier ALL voltage of xformer to do the bias. I'm thinking to do this ( see the attach file ). I see this on a HIWATT schematic for EL34, but without the potentiometer. Do anybody know who is a good idea put a ZENER with the bias voltage to make sure the voltage is low than -50v? I don't know the value of the resistor and the value of the potentiometer. Can anybody help me with this? Best Regards, Felipe Navarro
#7 |
I think what Wavebourne was getting at was the idea of putting a small resistor between the transformer secondary CT and ground. You lose some B+ that way, but a one component solution has its virtues.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#8 |
Using a zener to regulate bias is not a good idea unless the screen voltage is also regulated. When all voltages are unregulated, the plate current will go down when line voltage goes up, as control grid has more gain than screen, and dissipation is more or less constant.
Some other possibilities: a small transformer just for bias, or even a reversed 120:12V transformer connected to a heater winding to give 60VAC. Some amps used a capacitor as a dropping element from one side of the B+ winding - you'll want a cap of 1000V or more, though. How about combination bias? A 6V heater winding can give about -15V with a doubler, and the rest can be cathode bias. |
#9 | |
http://www.diyaudio.com/forums/attac...amp=1113901355 |
#10 | |
Geek, To I calcule the size of the resistors how many mA will use the grid bias of the 6l6? Best Regards, Felipe
| A-75 Bias voltage | Zapped | Pass Labs | 15 | 18th February 2011 01:35 AM |
| Magnetic tape head voltage output | tomcuk | Analogue Source | 11 | 30th March 2009 03:20 AM |
| bias voltage vs bias current | woodturner-fran | Tubes / Valves | 3 | 24th February 2007 11:24 PM |
| Regulate the high voltage making better sound? (Preamp) | 9999 | Tubes / Valves | 20 | 20th January 2005 05:21 PM |
| Page generated in 1.18819 seconds (7.65% PHP - 92.35% MySQL) with 11 queries |
