#21 |
hi Gordy,
Understand! hi Kevin, Actually I really happy to hear U well aware of the technical limitations of the F-5002. Do U had any more coment of Tamura OPT or different transformers we can discuss! Before I reserachdifferent brand of audio transformers such as Tamura. I keep stock of different productio period of them & test for their technical limitations about them! this is 1960~70's Tamura product. I test their technical limitations & compare with nowsdays trans. If data large improve. I always broken for them to compare test data or hearing imprvement was cause by, layered material or core or winding method or copper wire purity! hope can share with more! thx thomas photo show 1960~1970's Tamura audio transformers.
#22 |
#23 |
Hi Thomas,
I think it is good that you are making transformers, and I, and many others want to hear about that. Was just suggesting you provide a link to your pictures and information, rather than posting it all here.. Some day I may even be a potential client, you just never know. I ended my business in the early 2000 time frame, but in my limited experience both Tango and Tamura offered performance levels not really available here in the USA - at least at that time. I no longer have all of the details, but found that the F-5002 in normal use at 60-80mA in my amplifier design met or exceeded all of the performance specifications Tamura provided. Unfortunately at the time I did not have access to an AP, so I had to use my Amber 3501 and did a series of measurements at various plate currents, frequencies and power levels. While I no longer have the data, but I do clearly remember that it easily exceeded its specifications, particularly in regards to primary inductance. (I wasn't too surprised as Tam Radio specifies things very conservatively.) One of the things I wondered is how you actually measure the performance of your transformers? Do you drive them with a representative source impedance similar to the rp of the tube it is going to be used with, and in addition with a dc current superimposed that equals the operating current? I know you have an AP so that helps quite. When I test I usually use a circuit similar to what will be driving it in the application..
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#24 |
hi kevin,
very nice to discuss with U in here. I fully agreed for your comment about 5002. HF & atmosphere was really very good which compare to normally OPT ( HI-B) Vocal also smooth too. 5002 is a success product but looks it birth period amorphous production is not in high mature condition. price of core was expensive & crystalline looks still in micro crystalline or super micro crystalline only. Nano crystalline was promoted & mass production on recently time. 5002 was very good. If U use full range speaker. But if u use large size woofer large than 12' inch woofer. LF will little weak. that's why I combine & test different method for amorphous core & hope the bass maintain fast detail but deeper & less phase shift. Hashimoto winding method was very good but combine with tango X series winding can improve & air gap mst good fit with thin copper sheet. this is part of my experience. I really hope can discuss with U too. thx thomas hashimoto method I was reference for this.
#25 |
which better? Silk or James OPT for 300B
#26 |
in my opinion, al not good.
If budget averiable, choose Tamura F7001 or 2 ( 2a3 or 300B) F2007. Tango X-3.5S or tailor made model NY-15-3.5S. U will love them! thx thomas |
#27 |
The before and after break-in distortion presented by Thomas seems really startling. Improvement of several hundred percent? I have never seen such measurements done by anyone else. Are they typical?
#28 |
>>Are they typical?<<
In my experience with amorphous core inductances in measurement applications, rather not. Usually such changes point towards flawed manufacturing or handling process of the cores themselves, creating the necessity to "reset" them magnetically - just the same way one has to "reset" the magnetic properties of permalloy/mu-metal after mechanically forming (bending, cutting, pressing, drilling, ...) it by annealing it in a hydrogen atmosphere... Regards, mb-de === |
#29 | |
can you provide a link or info on the Loesch 50 amp? TIA, |
#30 |
Properly used, I prefer the James JS-6123HS (settin 3,5 kOhms to 8 Ohms).
This will hold up to a Tango XE-20S in similar settings. Both do not stand a chance against the Tango X30-3,5S (better overall balance) or X-3,5S (way superior in the low frequency regime, no surprise, if you take the core size into consideration). In check, all of these loose - for my ear AND for my testkit - against the Tamura F7002 (again unsed 3,5k:8R)... cleaner, dryer, more controlled, more low level detail... That one gets a run for its money from the Lundahl LL1623AM-PP in parafeed (used with setting 3k or 5,6k:8R), if you happen to find a good 120..300 Hy choke which has a good frequency response and will have to stand 80 mA DC (160 mA peak) without saturation, and in must be very wide-band. Best regards, mb-de === |
| Chinese Output transformer for 300B SET | ja2dhc | Tubes / Valves | 23 | 22nd February 2011 04:14 PM |
| SJS SE 300B with Interstage Transformer Mk2 | DVDHack | Tubes / Valves | 29 | 20th August 2008 11:52 AM |
| 300B shootout | aldovan | Tubes / Valves | 25 | 21st January 2008 03:56 PM |
| GTA 300B SE Mk.II Power Transformer | korneluk | Tubes / Valves | 4 | 17th December 2007 05:09 PM |
| Best output transformer for 300B | hnb2907 | Tubes / Valves | 8 | 4th December 2007 04:14 PM |
