diyAudio Sponsor
Old 12th October 2007, 06:02 PM   #1
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Default Single ended amp from class A push-pull
...it is amazing how tubes can fool human perception!
During the last concert I've discovered one 6P3S in my amp has glowing anode. It turned to be I've overbiased them, so evaporated anode metal shorted the path between grid and cathode so only -1V of bias voltage left in one shoulder (2 tubes in parallel)... Actually, it was a single ended kind of an amp as the result with much less output power and higher distortions if to measure them, but people kept saying it sounds brilliant... Go figure...
...so... what if to use a push-pull transformer with a FET current source?
The cheapest way to get a decent class A power amp!
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 12th October 2007, 07:56 PM   #2
smoking-amp's Avatar
Twice as much power and still giving SET sound using a P-P transformer:
(could just skip the cascode part and use a high voltage Mosfet like the FQP2N90)
http://www.diyaudio.com/forums/showt...668#post638668
Don
Ohms Law V = I R
Old 12th October 2007, 09:14 PM   #3
Wavebourn's Avatar
Thanks Don; now I am going to try it intentionally.
push pull Vs single ended class A amp space2000 Solid State 25 23rd August 2008 03:31 PM
Single-ended OR push-pull? kacernator Tubes / Valves 48 31st March 2008 02:50 PM
Is single ended Class A better than push-pull? okhifi Tubes / Valves 49 1st September 2005 07:26 PM
Parallel single ended or push-pull? Jeffy74 Tubes / Valves 6 12th February 2004 06:04 AM
Page generated in 0.07606 seconds (66.36% PHP - 33.64% MySQL) with 10 queries
