| diyAudio Sponsor | ||
are the low voltage tubes mainly good for unity gain or low gain in a preamp? i haven't found any amps using one in the output stage e.g. headphone amp.
a forum search says there's no substitute for high voltage. |
#2 |
6GM8 and 6DJ8 are commonly used in low voltage tube amplifier circuits, although for a headphone amplifier 24V is probably below the lower limit even with these tubes.
And yes there is no substitute for higher voltages.
www.kta-hifi.net |
#3 |
... maybe this one fits for you ... you can take an old pc power supply to feed them ...
![]() Details : DC @ Headphone 2.5 mA and 4 mW power loss. - passable Filament current 3.8V @ 600mA URL in German
the truth is somewere |
| Tube Noob! need help with tubes lots of tubes | therapy_fan | Tubes / Valves | 15 | 29th January 2009 09:01 PM |
| WTT: Various tubes for 6CA4/EZ81 rectifier tubes | GordonW | Swap Meet | 4 | 27th August 2008 12:37 AM |
| Switching 230 Volt Transformer to 120 Volt | OMNIFEX | Parts | 10 | 6th April 2008 04:34 PM |
| Volt in a TL | BlackCatSound | Multi-Way | 24 | 1st November 2004 07:29 AM |
| 12 volt DC to 9 volt AC | eRiCdWoNg | Parts | 10 | 18th April 2004 01:52 PM |
| Page generated in 0.06895 seconds (71.61% PHP - 28.39% MySQL) with 10 queries |
