| diyAudio Sponsor | ||
hello there
i am trying to design a single ended amplifier based on the kt88 beam tetrode. i have beed told i want about 40 - 45 volts peak to peak input in to the kt88 for optimum performance. from this i decided to use a 6sn7 for the driver stage, i played about with load lines for the 6sn7 for a while and found a simple common cathode stage using 1/2 a 6sn7 could provide a voltage gain of about 16 which would be perfect to turn a 2.88 pk-pk signal (1Vrms) in to a signal around 45V pk-pk. is this single stage enough, or should i consider other options to obtain higher gain,,, an srpp based on the 6sn7 for example. i was wondering about possibly having more gain available at the driver stage for low recording levels on music, any thoughts? cheers soundbadger |
#2 |
Search the forum for "Mikael's KT88". It is a single-ended KT88 design that several members have built. It uses 1/2 a 6N1P for the voltage amp. In mine I get between 7 and 8 watts with that schematic. Based on that you should be OK with your setup.
I use my amps (I built them as monoblocks) with CD, tuner, iPod and cable TV and all work fine as sources. I also use a turntable but of course have a phono preamp for that.
--Sherman |
#3 |
thanks, but your kind of missing the point.
there are hundreds of amp schematics out there i could build that would work and im sure lots of them are great. i have looked at mikaels amp in detail and even drawn its loadlines to get an idea of its operation. however i am trying to calculate everything myself,,,, |
#4 |
The 6SN7 will be adequate with a line stage that has some voltage gain driving it, consider the 6SL7 in SRPP - enough gain to do the job and run at 2mA should provide enough drive to deal with miller capacitance out to 30kHz or so.. (Triode connected, UL not an issue.)
I used 6SL7 in SRPP to drive my cheap and cheerful 45 SE amplifier - it's the oldest amplifier I still own, and sounds good within its limited power capability. Supply voltage to the SRPP would need to be over 300V for best performance.
www.kta-hifi.net |
| Single Ended, Single driver: In-room distortion measurements | Gerrit Boers | Full Range | 4 | 27th November 2007 08:12 AM |
| Help needed for LM3875 design + simple single-sided PCB. | Spasticteapot | Chip Amps | 12 | 2nd April 2006 07:25 PM |
| Single Ended Triode (SET) amp friendly design | GaryF | Multi-Way | 5 | 30th May 2004 04:30 AM |
| Anyone play with the Zen Single-Stage Single-Ended Class A? | Rino odorico | Pass Labs | 13 | 29th August 2002 09:01 AM |
| Page generated in 0.07280 seconds (76.32% PHP - 23.68% MySQL) with 10 queries |
