| diyAudio Sponsor | ||
I am looking for a tube to use in a preamp. I need a single triode, or pentode that can be triode strapped, has a mu in the area of 15 to 25, and has an rp of 2K5 or lower. Octal or loctal is ideal, but 9 pin will work, and if possible, a 12V heater is preferred.
I have already used 6688's and 7788's, so I don't want to use them again. 5842's and 7737's are a little too expensive, 12j5's and their variants have too high of an rp. 6t4 is a 7 pin but otherwise promising. C3m looks almost ideal except for the price and lack of availability. Really, I am looking for 1/2 of a 5687 if it exists. Any other suggestions?
http://www.ecpaudio.com |
#2 |
a 5687 paralleled? rp of 1000 or so
#3 |
ECC99 has rp of 2700, mu of 22, and 6.3 or 12.6 heater. Both section could be ran parallel for even lower rp.
#5 |
Borderline between big signal tubes and little power tubes...
Maybe triode-connected 6CL6, or 12EH5/12CA5? Cheap and worth a try... I know there are also similar tubes in loktal bases, just don't know the numbers offhand. Try cruising through the "14xx" tubes in the Sylvania manual: http://www.pmillett.com/sylvania_tub...als_online.htm you might see something good. Pete |
#6 |
How about a russian tube? 6s3p-E. If you can, get the one with the "E" marking.
But I would highly recommend c3m, you can get them easily. siang |
#7 | |||||
I'll look for a loctal too. Quote:
#8 |
Keep in mind that for what you are asking, there will be trade off's.....such as a hefty bit a DC idle current for your requirements,,, None the less....to answer your request, take a 6V6 in TRIODE mode...Rp is about 2.4K and the mu is about 10....and it is an octal base....
Either tie the L and R stereo 6.3V heaters in series for 12.6V or use the 12V6 ..... Should get the job done.... Chris |
#9 | |
That's a good idea. I was thinking EL84 variants -- 10BQ5, etc. or maybe even a 12W6GT? I've used 6W6GT's before and these are a real sleeper -- good sound for no money at all.
#10 |
I'm going to take some liberties with your request, and recommend the 5676. This is cheaply available and mu of 15 but different in all other respects. Miniature directly heated triode with four wires coming out the bottom. So various ways of attaching. I solder to a tag strip. Must be used vertical, and must have a good DC supply to each tube, though this is low current. Batteries are another possibility. It's not particularly microphonic.
What you will get is crystal clear sound - it's in my current favourite preamp, working parafeed. This tube came close to winning the European Triode Festival prize for phono stages in one design. http://www.rintelen.ch/hifi/lil_sis.pdf You could be very surprised! |
| Best Cheap Speaker for Single Ended Triode | Patrick Bateman | Multi-Way | 16 | 22nd December 2006 09:17 PM |
| Why no single triode OTL power stages? | leadbelly | Tubes / Valves | 28 | 15th February 2006 06:17 PM |
| a single double triode and two chanel? | killerfishes | Tubes / Valves | 2 | 14th June 2005 12:16 PM |
| DIY Single Ended Triode Designs | jesserparker | Tubes / Valves | 35 | 23rd March 2004 12:21 AM |
| Page generated in 0.10927 seconds (83.65% PHP - 16.35% MySQL) with 11 queries |
