diyAudio Sponsor
Old 9th October 2007, 10:27 AM   #1
soundbadger's Avatar
Question Another Power Supply Question
right so to deisgn a power supply i need to know the voltage desired and the current that will be drawn,
but from the curves for the kt88 (my output tube of choice for my amp) i have noticed that when in triode mode (as i want a switch to allow mode changing) the kt88 idles at 60mA as opsoed to ultralinear mode at 80mA.
Old 9th October 2007, 10:46 AM   #2
Tweeker is offline Tweeker  United States
Anode voltage will be somewhat higher in triode mode, depending on regulation.
If choke input you must size the inductance for triode mode. Triodes like a stiff psu.
Hotswitching modes may be problematic.
Be sure your foil hat has a good low impedance ground.
Old 9th October 2007, 10:58 AM   #3
i did i simulation of an idea in duncun psu designer and when i go from 120ma draw (both tubes in triode mode) to 160ma draw (both tubes in UL) i get a voltage drop of about 15V,,,
is there anything i can do about this?
oh and i wouldn't ever hot switch anyway to many expensive components to potentialy damage..
Old 9th October 2007, 11:07 AM   #4
just to let you know the amp is kt88 based single ended design with an HT / B+ voltage of 500v....
Old 9th October 2007, 11:43 AM   #5
About the only thing you can do to reduce or eliminate it is build a beefier supply with less losses, or active regulation.
A somewhat higher anode voltage in triode mode isnt a disaster (assuming it doesnt take parts past ratings), check for the current it will draw at this different operating point.
Alternate bias for triode mode is another possibility.
Old 9th October 2007, 11:57 AM   #6
i think ill just work out what voltage it will be getting in in triode mode, draw an appropriate load line and have a look. as like you say the 15v increase shouldnt affect its behavior too much.
Old 9th October 2007, 12:22 PM   #7
heres the schematic
Old 9th October 2007, 12:25 PM   #8
and heres a plot of the voltages over the 2 current dains (the 400v line is for the preamp) at 5 seconds the main drain switches from 120mA to 160mA.
Old 9th October 2007, 02:13 PM   #9
zigzagflux's Avatar
That 31 ohm resistance for the transformer seems a little low. That would be a fairly large transformer. You sure about that?
Old 9th October 2007, 03:31 PM   #10
no not sure at all, neither am i sure of the cap's resistance ,,
they are just the figures that were on the parts in the psu designer,,, i should adjust them accordingly but i dont know what to ,,, a bit of reading might be order...
Amp power supply question theAnonymous1 Solid State 12 30th August 2008 05:06 AM
813 power supply question Richard Ellis Tubes / Valves 6 14th December 2007 03:41 AM
Power supply question HugoR Tubes / Valves 9 9th November 2005 08:34 AM
Power supply Question Adam M. Chip Amps 10 4th May 2005 02:19 AM
Power Supply Question RichardJones Tubes / Valves 41 28th April 2003 03:12 PM
Page generated in 0.11292 seconds (74.63% PHP - 25.37% MySQL) with 11 queries
