diyAudio Sponsor
Old 9th October 2007, 04:18 AM   #1
Default 2a3 output transformers....
I've got a MIDWEST AUDIO 2a3 valve amp which I love and sounds great. However I've discovered it's using just Hammound ot's !! The 125s's... So I know It will sound better with some real iron. The only real facts I have are it's at least 70ma out. 16 ohm speakers, the km-30 phy-hp's (13.8) with 370 vdc input max. From stuff I've read it may need a 2500 ohm primary ? Are possible choses: Magnaquest, llunduhl (expensive) and the hammound 1627's ? What's your opinion ????? Thanks, Mike
One last thing my speaker are only 97 db so I hope the 2w I have won't be reduced with a different trans. Which has the lowest hum ???????
Old 9th October 2007, 04:28 AM   #2
frugal-phile(tm)
planet10's Avatar
Contact Bud Purvine (aka BudP here) at O'netics.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th October 2007, 05:39 AM   #3
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
I use MagneQuest DS-025 on my 2A3 amp and love them.
You've got other options, like what Dave mentioned, and others such as James (on my 300B amp).
Old 10th October 2007, 02:05 PM   #4
number9 is offline number9  United States
Years ago I built a SE 300B amp and owned at the same time a pair of Electra-Print, Audio Note (English), and MagneQuest OP transformers. In the long run I could only keep one pair. I auditioned each pair on Quad EL57 speakers. The only difference I could hear was in the base. In the midrange it was a draw. I decided to keep the pair that has the best bass with those Quad speakers. I decided that interaction between the speakers and those transformer was the best match. I later learned when you order from a boutique winding shop, the winder can set the air gap to the current of the output tube. If I were you I would upgrade the coupling caps. More result for the buck spent. Other effective use of your dollar, upgrade of the resistors to tantalum (see Parts ConneXion catalog) , higher wattage values sound the best. Upgrade of the power supply caps, if you have the room, to Nichicon KG caps (see Michael Percy catalog). They can make the amp sound faster all through the amp’s frequency response. The best sound will come from an upgrade to very large polypropylene caps (see Michael Percy catalog). If you have the real estate below deck and can mount the terminal strips below deck. Each one of these changes adds a small percentage of improvement. You will notice the most expensive tube amps all have these improvements at delivery. On another point, you will not hear any difference in the hum level between these transformers. You are using very efficient speakers and you should expect some hum unless the amp builder has the knowledge and done the work to eliminate the hum before delivery.
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
Output Transformers eduardio Tubes / Valves 2 13th May 2005 02:42 PM
Using output transformers on Zen Amp? G Pass Labs 14 5th November 2004 11:54 PM
SE Output Transformers DVDHack Tubes / Valves 32 19th January 2004 10:52 AM
Page generated in 0.08522 seconds (74.12% PHP - 25.88% MySQL) with 10 queries
