| diyAudio Sponsor | ||
I've been intrigued by these small metal tubes and have designed an amplifier to use them. What do you think?
http://www.shinjo.info/frank/sheets/093/6/6AG7.pdf
#2 | |
Of course, the only way to be sure is to go ahead and do it. If you don't try, you won't know. |
#3 |
The 6AG7 has pretty high sensitivity, so it strikes me it would be ideal in pentode with plate-to-plate feedback to it's driver stage (of course it would have to be something other than a 6SN7 then) or a 'super triode' connection. As Miles said, it has a very high Rp but also high gm, so a high amount of NFB would seem expected. It is better to then have most of it without the output transformer in the loop.
#4 | |
#5 | ||
The original use was as a vid amp that could have an f(h)= 4.0MHz, and slam current into a CRT's Ci. They also frequently turn up as ECOs (buffered and/or with frequency multiplication) in ham rigs, and as horizontal deflection amps in o'scopes. Quote:
#6 |
Cool. As an extra measure, I'm switching to a 6N7 driver tube. It seems to have similar headroom in the place of a 6SN7, and the extra gain will help feed some NFB. Any extra gain after that, I'll burn off with the volume pot. This is an integrated amp design.
As I mention over at AA, using all metal tubes is nice because I get to mount them inside a cool rackmount chassis without feeling bad. I'm assuming I'll use SS rectification, but are there any metal rectifiers that could put out around 150-175mA safely? That'd be icing on the cake |
#7 |
I have enough 6AG7s that I could use them as the input stage, PPP outputs, and a few more as rectifiers...
Seriously, the 5T4 is the biggest metal rectifier, but not all that common. It's 6L6 size, except for the earliest ones, which are bigger. I have a few metal 6X5s, 5W4, even 25Z6s. |
#8 |
This is slightly off-topic, but I will ask it anyway. I have a handful of these 6AG7 tubes and was wondering what to do with them. I contemplated making an audio amp, but I will probably use 6V6 or 6550. Do you guys think that a 6AG7 would make a good power final for small AM/SW transmitter (I plan to use it to transmit to vintage radios)?
#9 | |
#10 |
I was going to try the 6AG7 as a driver for a bank of 6080`s parallelled up in SET. With the ability of the 6AG7 to swing big into a low plate load R I thought this might help deal with Mr. Miller.
The 6CL6 is almost identical to the 6AG7 and comes in a 9 pin miniature bottle.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
| 6P9/6AG7 Triode Amplifier | sorenj07 | Tubes / Valves | 3 | 26th October 2007 01:50 PM |
| 6AG7 UL Curves | sorenj07 | Tubes / Valves | 6 | 16th October 2007 05:17 AM |
| 6ag7 metal pentodes | martinab2 | Tubes / Valves | 4 | 8th October 2007 07:30 AM |
| Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier | Audiophilenoob | Swap Meet | 34 | 16th May 2005 11:58 PM |
| Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 2 | 21st October 2002 01:50 AM |
| Page generated in 0.11752 seconds (79.64% PHP - 20.36% MySQL) with 11 queries |
