PCB design techniques for Tube Amps
Old 28th July 2013, 07:54 PM   #21
12E1 is offline 12E1  United Kingdom
12E1's Avatar
Originally Posted by roline View Post
...I solder all eyelets to the traces and no problems.
Thanks. I guess it's down to understanding the issues (as you clearly do) and taking sufficient care with the joints. Interesting stuff.
Old 29th July 2013, 08:07 PM   #22
tomchr is offline tomchr  Canada
tomchr's Avatar
I use double-sided PCBs all the time. I oversize the pads and traces to prevent lifting. My boards survive multiple rework operations without peeled traces. The through plating also helps against trace lifting.
A PCB beats point-to-point wiring in repeatability hands down. And a properly laid out board will perform as good or better than point-to-point wiring simply because the board can easier be optimized with respect to signal integrity.
For prototypes I make double-sided (not through-plated) boards using toner transfer. With those I do sometimes run into trouble with lifted pads or traces resulting from repeated rework. But most of the time the issues are caused by a slight slip between the top and bottom layer artwork throwing the registration off by maybe 0.25 or 0.5 mm. It's good enough for prototypes and one-off kinds of jobs, but for anything else, I'd go with a professionally fabricated board.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
PCB design techniques for Tube AmpsHide this!Advertise here!
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 06:04 PM
Numerical Solving Techniques for Optimum Crossover Design thadman Multi-Way 5 21st May 2009 06:29 AM
First Watt F3 / Tube Audio Design TAD-125 Hibachi JFET amps vizion Tubes / Valves 1 31st August 2008 04:08 AM
Tube pre-amps Glowin Plates Instruments and Amps 5 20th May 2004 07:30 AM
Op Amps for Everyone Design Guide (Rev. B) lohk Solid State 2 14th July 2003 12:15 PM
Copyright ©1999-2017 diyAudio
