diyAudio Sponsor
Old 7th October 2007, 01:46 PM   #1
Default 6C33C-EB / 6C33C-EV extended life ?
Hello
I Just read that the 6C33C-EB or 6C33C-ES have a 3000 hour service life instead of 1000 hour.
I did expect some reliability problems with some 6C33C-B .
Should this be an issue !
regards
ger56
Old 7th October 2007, 03:55 PM   #2
The life time given in the data sheet is when running the tubes at max allowed parameters and within this life time the tube will still fulfill conditions that are valid for military applications. In practice there is no difference between different 6C33C tubes they are just sampled and tested differently and therefore have different classification.
For Audio usage the service life is very long, easily exceeding 10000 hours. I have used the same set of tubes in my OTL for more than 6 years without problem and even longer in a SET amplifier. My experience is that 6C33C tubes have longer life than more common power tubes like EL34.
In short, don't worry!
Regards Hans
Old 14th October 2007, 05:54 PM   #3
NJE807 is offline NJE807  United Kingdom
The 6C33C data sheet includes an operational temp range of -60 to 100 degrees C, and also a maximum acceleration rate, (rectifier tube, jet fighters for the use of)! Unless you are trying to get 60W out of them, they should last a long time.
6C33C-B. PP or SE ? Predator864 Tubes / Valves 471 14th February 2011 09:30 PM
6c33c PSE mark_titano Tubes / Valves 13 20th December 2010 04:49 AM
6c33c-b & 6c33c-v skybird Tubes / Valves 4 21st April 2009 06:21 AM
WTB 6c33c-b woody Swap Meet 0 20th September 2005 07:36 PM
6C33C and GM-70 Colt45 Tubes / Valves 21 20th November 2002 11:38 PM
Page generated in 0.07274 seconds (70.67% PHP - 29.33% MySQL) with 10 queries
