diyAudio Sponsor
Old 4th October 2007, 07:31 PM   #1
jayme is offline jayme  United States
Default transformer secondary connections
It is my understanding that VTL amps tie together all of the output transformer secondary taps, for a nominal impedance of 5 ohms.
Does this offer any benefits over traditional discrete secondary connections (4/8/16 ohms)? What are the drawbacks?
I am planning to build a SE EL34 amp, switchable between triode and UL...probably something based on Mikael's simple KT88 design posted here.
confusing transformer connections audio_moksha Tubes / Valves 0 13th March 2008 03:07 AM
Hammond Transformer Secondary Connections Mush Tubes / Valves 7 1st October 2007 08:13 PM
help with transformer secondary jarthel Power Supplies 34 8th July 2006 01:01 AM
Transformer connections gcnewbie Chip Amps 6 18th April 2005 06:54 AM
Page generated in 0.06059 seconds (62.73% PHP - 37.27% MySQL) with 10 queries
