6n6p amp - diyAudio
Old 1st October 2007, 11:59 AM   #1
Question 6n6p amp
Does any one know of a simple output schematic for this tube?
I searched on the net and it didnt turn up much.
has anyone used them and how did they perform?
I have aquired a small quantity and was wondering how much power I could get out of two tubes a side in push pull (i think it would be about 7W)
Any advice would be appreciated.
Cheers
Old 1st October 2007, 01:16 PM   #2
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Here's a bunch:
6N6P PP
6N6P PP
6N30P-6N6P PP
6N6P PP/SE
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 2nd October 2007, 01:48 AM   #3
Very nice, I had already found James Doddingtons design posted on U tube, but I could not get a clear screen shot of the schematic.
The 6h30 it 6h6p schematic looks like an interesting amplifier to build with its transformer coupling.
I have a bag full of mic imput transformers 600ohm to 10k ohm ct, hopefully I can throw in a pair back to back for the driver stage and use one as an imput.
It looks like a 6n6p needs a 5k-7k plate load from the schematics posted above. ( a bit like a pentode)
My understanding/ misunderstanding was that triodes have lower plate impedances and this meant output transformers ranging from 1k-5k.
Interesting...
OPT impedance affects damping doesnt it?
As this amplifier is an experiment i think i will use a small 100v line transformer as the opt device, getting even cheaper would be to use a small power transformer as an output transformer.
But has anyone had luck with this?
As id imagine the Lf response would be good but the upper end 500hz and up could suffer a lot.
If these slack ideas fail ill build it properly the second time around, ill never know untill i try it.
6N6P vs. 6N6P-I sparkle Tubes / Valves 60 13th April 2013 03:15 AM
New 6N6P linestage Brit01 Tubes / Valves 8 25th July 2009 07:44 PM
6N6P in an Aikido? Burnedfingers Tubes / Valves 29 20th January 2009 09:14 PM
Cascoded 6N6P croccodillo Tubes / Valves 5 29th June 2007 11:35 AM
Help with 6N6p dsavitsk Tubes / Valves 10 29th March 2007 10:34 PM
Copyright 1999-2017 diyAudio
