6SL7 EL34 300B amp
6SL7 EL34 300B amp
Old 1st October 2007, 04:32 AM   #1
MartinV56 is offline MartinV56  Colombia
MartinV56's Avatar
Default 6SL7 EL34 300B amp
Hi folks.
My first DIY amp is 6SN7 cascade to drive 300B, similar to Sun Audio circuit.
The 6SN7 is very good tube sound but my next project is with pentodes drive the 300B.
Here the circuit
I thank for yours commentaries and suggestions, thanks
Old 1st October 2007, 03:00 PM   #2
Andrewbee is offline Andrewbee  Jamaica
that circuit looks familiar
It appears you have changed the original 12AT7 input tube to a 6SL7 but have kept the original component values. Also replaced the vacuum rectifier with SS diodes.
Also, while the EL34 is a pentode it is being used as a pseudo triode, notice the 100R resistor between the plate and G2.
What is wrong with the original circuit in your opinion?
Andrew
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 1st October 2007, 06:21 PM   #3
MartinV56's Avatar
Thanks, the original circuit is this:
The differences are minimum, 6SL7 bases octal is very similar electrically to 12AT7, the resistance operates like a bride.
Very I am not convinced of the use of pentodo like driver of 300B, have my doubts on the matter, Perhaps goes pior the WE-91 amp or 6C41Pi IT 300B, thanks again
6SL7 EL34 300B ampHide this!Advertise here!
EC52--Plate choke--300B/45/2a3/50/EL34 SE tube-lover Tubes / Valves 11 4th October 2011 06:39 PM
SE EL34 schematic HELP: from two 6SL7's to One? ambience exists Tubes / Valves 13 14th March 2010 05:48 PM
Best way to use a PAIR of 6SL7ís to drive a 300B? sgerus Tubes / Valves 5 11th December 2007 12:41 AM
6SL7 driving SE EL34 ? Gwaltinger Tubes / Valves 7 20th January 2006 04:57 PM
6SL7 + EL34 SE Audio Amp dr._sleep Tubes / Valves 5 31st October 2005 08:11 AM
