I just installed Yeos (DIY Paradise) DC Blocker I just installed Yeos (DIY Paradise) DC Blocker - diyAudio
Old 1st October 2007, 02:06 AM   #1
duderduderini is offline duderduderini  Australia
Default I just installed Yeos (DIY Paradise) DC Blocker
Hi Guys
I have been meaning to try this dc blocker and i have just installed it into my test rig amp.
http://www.diyparadise.com/dablok.html
Well I will be blowed if there isnt an net overall improvement, in particular the amount of airiness in the music. It certianly hasnt degraged the sound.. the trans doesent buzz as much either.
Anyone else tried this trick?
Nick
"Better to say nothing and keep them guessing than to speak and remove all doubt."
Old 1st October 2007, 04:38 PM   #2
kevinkr's Avatar
Interesting idea, several things need to be mentioned:
The entire load current is flowing through those capacitors for one half of each cycle, better make sure that the ripple current rating of that cap is considerably greater than load current. Excessive heating and early failure could otherwise be the result.
As the caps age their ESR will increase, resulting in increased internal heating, eventually you could be in for some excitement as the caps fail.
Should one of those diodes fail the associated cap will be subject to the reverse voltage the diode was clamping.
Shorts on the secondary side of the power transformer may result in substantially more voltage appearing across the cap than it is rated for. I would consider replacing the diodes with high power zeners to protect against the above failure.
I'd use at least 50V caps for this application and probably more than one diode per cap just to play it safe.
The fuse should be placed before this network so in the event that something fails there is some protection against the hazards this circuit introduces under some fault conditions.
On the surface this looks like a good idea, on closer inspection I am not quite so sure - enough so that I would not use this technique with the components suggested in the note.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 1st October 2007, 04:47 PM   #3
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
I just installed Yeos (DIY Paradise) DC Blocker Send a message via AIM to Peter Daniel
Default Re: I just installed Yeos (DIY Paradise) DC Blocker
Yes, I tried it. Even here the signature of capacitors can be heard and in a long run I didn't like it.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 2nd October 2007, 01:36 AM   #4
lousymusician is offline lousymusician  United States
Is there a better approach to achieving the same result?
Insert witty signature line here.
Old 2nd October 2007, 02:27 AM   #5
kevinkr's Avatar
If you can afford it a dedicated line is best. (I have 4) Look for old style dimmers and ancient tv sets as possible culprits that inject dc onto the power line.
Bulb savers advertised and sold in super markets and drug stores are nothing more than half wave rectifiers - if you are using any they should be removed.
Note that all of the above presupposes that there is no significant dc coming into the house. (Pole transformer not shared with neighbors, or neighbors who do not have devices that put much dc on the line.
Frankly I suspect most large utility transformers are quite good at suppressing moderate dc appearing on their windings, so it should be a local problem only. This incidentally isn't a problem I have ever encountered anywhere I have lived in MA or NH over the last 30yrs.. (Too many places to count.)
Forget about it..
Old 2nd October 2007, 02:44 AM   #6
sorenj07 is offline sorenj07  Germany
sorenj07's Avatar
would some huge isolation transformers work in the same way? how does balanced power work again? (I could search but I'm lazy)
Old 2nd October 2007, 03:02 AM   #7
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
not really. the way i see it, without using a dc blocker, one has two choices:
1. remove the source of the dc (e.g anything on the power lines that half wave rectifies, etc.)
2. replace the power transformers in the affected equipment with transformers that are less susceptible to the dc that is present.
ok, i guess there is a 3rd option that we don't like: grin and bear it.
peter:
what effect did you hear that makes the dc blocker not an option for you? i'm curious ...
mlloyd1
Old 2nd October 2007, 03:08 AM   #8
It was coloration, and I suspect it comes from capacitor.
www.audiosector.com
Old 2nd October 2007, 03:56 AM   #9
Conrad Hoffman is offline Conrad Hoffman  United States
Agree with the above safety/overload considerations, but also, since the current is the same on both sides, why not put this thing on the neutral side so it isn't sitting at line potential? Given the area of the cans, my guess is any sound difference you hear is somehow related to the field, not the designed function of the device.
Old 2nd October 2007, 07:43 AM   #10
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Default Re: Re: I just installed Yeos (DIY Paradise) DC Blocker
Interesting. I also tried and loved it for a few days. As original poster mentions - improved "airiness". Sadly, the bass was obviously coloured.
I just installed Yeos (DIY Paradise) DC BlockerHide this!Advertise here!
dc blocker test report jeapel Pass Labs 5 4th July 2007 04:46 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright ©1999-2017 diyAudio
