Need the Ogirin Circuit of Bruce Berman - diyAudio
Old 30th September 2007, 04:45 PM   #1
Default Need the Ogirin Circuit of Bruce Berman
Hi every body.
I need Origin circuit of Bruce Berman about Pre amp using 76/6SN7, that was post in Sound Practice 13.
Thank you so much
my email : e.hopthu-at-gmail.com
Old 2nd October 2007, 07:18 AM   #2
Up now
Old 2nd October 2007, 03:04 PM   #3
dady is offline dady  Europe
dady's Avatar
Send a message via MSN to dady Send a message via Skype™ to dady
Default did you get it?
If not please tell me, I have it.
Esteban Bikić
Old 2nd October 2007, 03:12 PM   #4
dady's Avatar
Default a litle description
76 is loaded with a 33k restsitor biased with an unbypassed 1k5 cathode resistor, direct coupled to 1/2 a 6sn7 which is a cathode follower loaded by a 20k cathode resistor.
There is a 1uF dc protection cap on the output and a 1 meg shunt resistor to maintain stability should it be disconnected from the power amp while it is turned on.
B+ is 400v, there is no decoupling between V1 and V2 but the two channels are seperated by a pair of final LC stages.
It is very elegant and as an early design has been borrowed from many fold.
Esteban Bikić
Old 2nd October 2007, 03:58 PM   #5
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
I doubt if anybody will post it because it's copyrighted material from Sound Practices.
If you want something similar, search for JE Labs 76 pre-amplifier which is derived from Berman's.
Old 2nd October 2007, 04:15 PM   #6
Thanks Dady !
What is about Power supply ? and do you have drawing ? can you send it for me ?
Thank so much.
Old 22nd May 2010, 06:01 AM   #7
anyone here can sent me a schematic of the Bruce Berman 76 preamp circuit? thank you
Berman 76 preamp schematics arnoldc Tubes / Valves 12 17th February 2014 09:06 PM
Berman linestage- do I reference heaters or not?! tmhajw Tubes / Valves 10 18th January 2009 03:51 PM
Bruce + subwoofer broughd Full Range 45 19th December 2007 03:09 AM
BIB or Bruce 1.1 for AN8 hwong Full Range 42 17th January 2007 10:49 PM
Copyright 1999-2017 diyAudio
