6p45c
6p45c
Old 29th September 2007, 09:21 AM   #1
Boris Minchev is offline Boris Minchev  Bulgaria
Default 6p45c
Hi. What's your opinion for that tube? Have you ever made an amplifier with it? It's a russian tube i think.
Old 29th September 2007, 09:40 AM   #2
Gluca is offline Gluca  Italy
Gluca's Avatar
6C45P? 6S45-PE?
Yes, nice and cheap (and 1W or so only)
Old 29th September 2007, 11:18 AM   #3
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Originally posted by Gluca
6C45P? 6S45-PE?
Different tube altogether. 6P45C is like EL509.
Old 29th September 2007, 11:53 AM   #4
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
6P45S is. 6P45C doesn't exist.
Old 29th September 2007, 12:06 PM   #5
analog_sa's Avatar
Mixing cyrillic and latin characters is so common with respect to russian tubes i don't even notice it.
Old 29th September 2007, 04:10 PM   #6
6P45C I'm sorry I made a mistake but i was not sure how to write it in latin cuz in cyrillic its 6П45С
Old 30th September 2007, 12:31 AM   #7
KaDe is offline KaDe  Germany
KaDe's Avatar
Default El509 = 6kg6 = 6p45c (6p45s) Ussr
Hi Boris
A good amp using this valves is the Omak Jewel One.
Omak Amplifiers
Old 30th September 2007, 03:08 AM   #8
CLS is offline CLS  Taiwan
High gain, low Rp, medium Ip => a good driver.
Old 30th September 2007, 08:41 AM   #9
igormak is offline igormak  Russian Federation
igormak's Avatar
Boris, primary this tube used in old russian color TV's for line and HV stage. I know some men which made amps with it.
For ex. Manakov's amp (in Russian):
http://www.rsu.edu.ru/~foboss/hi-fi/...6e5p_6p45s.pdf
Old 30th September 2007, 10:16 AM   #10
ilimzn is offline ilimzn  Croatia
6P45S is only similar to EL509 and will usually work in circuits built for the EL509. Internally, it is however a very different construction. It is a frame grid beam tetrode, and actually uses frame grid construction for both G1 and G2. Compared to the EL509 it is also quite bit more massively constructed, with very thick bulb glass - it weighs a good 60% more than an EL509. It's G2 also appears to withstand higher voltages when operated as a triode, compared to the EL509.
6p45cHide this!Advertise here!
Resources saved on this page: MySQL 17.65%
