DRD Power Supply - diyAudio
Old 27th September 2007, 04:00 AM   #1
eeyore is offline eeyore  Australia
Default DRD Power Supply
Trying to spec out a PSU for Electra-Print's DRD 45. Just wondering, if the PI filter, and a SS diode rectification, what would be a better PI filter, given they are both using a 20H choke.
1. 100uF + 100uF Oil Film Caps (ASC)
OR
2. 500uF + 1000uF Electrolytic (Panasonics)
Which would have better bass response? Damping? Sound better?
Thanks1
DF
http://diy-audio-blog.blogspot.com
Old 27th September 2007, 11:07 AM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hard to say. Therefore I would say try them both...see which one you prefer...and tell us.
Generally speaking though..the ASC's should sound better. Because I find lytics...give the sound a slight edginess. On the other hand some panasonics are quite good. And might make the amp a little quieter.
Have a read in this paper...which I translated from DHTROB's website. My translation is not all that good...but you'll catch the drift.
Not a peer reviewed textbook...but I think nevertheless an interesting hands on guide based on experience of an experienced SET amp builder.
http://basaudio.net/pubs/dhtrob_psu.pdf
planet10 needs your help:
Let's help Ruth and Dave
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Copyright 1999-2017 diyAudio
