| diyAudio Sponsor | ||
#11 |
Theese Ê42-Ó2 are without any oil, simplifying the sound, not best choice for amplifier.
They were discussed at our russian forum "Audioportal".
#12 |
For hifi use get some of the FT-3 metal cased Russian teflon ones instead, they're stunning. Most of the ex military stock, tubes, sockets, and caps I have purchased on eBay have been at least "pretty" good and are very inexpensive compared to comparable parts made here.
I have purchased caps and tubes from eBay vendors, sometimes repeatedly: alexer1 kievfilarmony and can unhesitatingly recommend them. (No affiliation whatsoever) edit: For guitar amp use those paper caps might be just the ticket, you'll have try them to see what effect they have on tone..
www.kta-hifi.net |
#13 | |
Blame the Manichaeists |
#14 | |
www.kta-hifi.net |
#15 |
I'm considering the K72P-6 .018µF teflon caps for my octal champ, to give it a glassy tweed tone.
The price is fantastic! |
#16 |
Yikes, what a scrambled mess of a post. Teaches me to not type during conference calls. Sorry about butchering your name Kevin, and I meant the K72P-6! Incidentally, for small values the FT-1 is terrific, all non-magentic construction and apparently copper leads. The 5.6nF works a pip in a Scott LT-110B at IF and lower frequencies.
#17 |
I was thinking about these as closest to .022 and .047:
.022uF 400V PIO K40Y-9. .018uF 500V teflon K72P-6 .033uF 400V PIO K40Y-9. .033uF 500V teflon K72P-6 I was thinking it might be cool to do a "Capacitor Shootout" and compare them to yellow Mallory caps in a guitar amp. |
#18 | |
Definitely worth doing imho, but make sure you compare to them to the same value mallory caps to avoid tonal shifts due to different -3dB LF cutoffs. Wouldn't hurt to value match them on a capacitance meter. Probably a no brainer..
www.kta-hifi.net |
#19 | |
I'll check out the FT-1 when I need to order some small value caps. I need to start looking for some better caps for the passive riaa equalizer in my phono stage. I'm always amazed at the low prices these go for relative to comparable western caps, and I suspect they are far better than the ubiquitous bumble bees some people still love..
www.kta-hifi.net |
| Just bought some of those Russian paper/oil caps off of ebay | aletheian | Tubes / Valves | 31 | 23rd October 2005 09:46 PM |
| How good or bad are the russian teflon caps | Bernhard | Parts | 10 | 25th January 2004 11:32 AM |
| Paper in Oil caps - any good? | Paulr | Parts | 4 | 20th August 2003 11:16 AM |
| Russian oil caps ? | Tomatito | Tubes / Valves | 38 | 20th July 2003 01:57 AM |
| Page generated in 0.11999 seconds (76.57% PHP - 23.43% MySQL) with 11 queries |
