well that sounds like some strong advice. I do have a few sets of the gold plated insulated RCAs around - I can sub those in.
only one other question - so I should put a 10nf cap b/w the RCA input jack ground and the ground buss. Is this the only ground path for the ground of the input jack?
I have never understood the reason that phonographs have a dedicated ground wire in addition to the 'grounds' of the two phono jacks. Perhaps this is the basis of my confusion.
anyhow, thanks again for the advice. I am really looking forward to getting this thing cookin 100%. c/
eddievanjealous said:well that sounds like some strong advice. I do have a few sets of the gold plated insulated RCAs around - I can sub those in.
You are confusing signal ground, AKA common return, with chassis ground. The 5th wire from the TT is a chassis ground that's tied to the preamp's chassis. The 10 nF. caps. are noise suppressors. They connect to the chassis, not the signal ground bus. The shielded "twinax" wire I previously mentioned provides the connection between the I/P jacks and the signal ground bus.
McMaster-Carr is an industrial supply house that stocks RFI suppressing ferrites and all sorts of "GOODIES" a DIYer can use.
RF problem - update II
hi again all,
so i tried eli's suggestions, thank you very much eli... i added the insulated gold-plated input jacks and the 10nf ceramic caps from input signal ground to chassis. Input signal ground also directly connects to copper ground buss which serves entire unit.
this seems to have solved the RF problem when i use my stanton DJ cartridge, but made the RF problem WORSE when i use the grado!
on the plus side, the sound quality has improved (more treble extension - this thing really sounds fantastic now) and the hum has dropped a few DBs - to the point where it is well, well below the surface noise of an LP.
anyhow, there are clearly a lot of factors at play here which i do not really understand. WOW this a lot tricker than building a guitar amp or power amp.
anyhow, i want to hold-off on using the ferrites because my decks/carts sound 100% fine when i use my solid-state pres, so i assume that this problem is correctable fully within the world of the pre amp itself. ???
I was going to try this suggestion next: " put a 47pF from grid to cathode."
Right now i am using a 820ohm grid stopper, I was also thinking of increasing this to 1500 or so.
If anyone has any other ideas, i would love to hear 'em! you have all been a tremendous help, thanks so much.
hi again all,
Is it ever. Ironing the kinks out of a phono preamp may very well be the toughest of DIY jobs.
100 Ohms is plenty for use with 12AX7 sections. Are the stoppers Carbon comp.? If not, replace them. Also, the bodies of the stoppers should be a close to the tube socket lugs as you can get.
Get the ferrites! Grado carts. are intentionally unshielded, while Stanton carts. are shielded. IMO, there's sufficient proof that the cart. and cables are acting as an antenna.
BTW, did you put shields on the 12AX7s?
reply to eli
hi eli,
yes i am using carbon comp 1/2w. the bodies are against the socket. i AM using tube shields, but they have no bearing on anything whether they are on or off.
this has been my general experience with tube shields - i have never experienced them making a difference - EXCEPT for the one time that i used a 12at7 paralleled as a current amp - i put a shield on it and the tube (a NOS GE or something similarilry valuable) DIED, and i mean, died, in 5 minutes flat.
Eventually I WILL get to the ferrites - i really need to get this thing working, it just sounds so great that i really want to use it (i transcribe a lot of vinyl to CD).
I guess i just assumed that if the same TT output cables cause no problem with the SS pre-amp, IE, they do not need the ferrites to function properly in that scenario, I can;t understand why they are necessary in with this pre-amp.
granted, i trust your advice that they will solve the problem, but perhaps there is a more elegant solution that is eluding me?
c/
hi eli,
c/
Success! Phono pre RF is cured
Alright. After many attempts at removing the dreaded WEBE 108FM from my RCA receiveing-tube-maunal dereived phono pre, I can finally report that the problem is gone, and with no noticeable loss of high end when a/b-ing the signal against the phono pre-amp built into my $250 yamaha receiver. FYI i am using a GRADO green cartridge and listening on AKG 240's and Yamaha NS30s (NS30s driven by my homemade 6SL7/ 2A3 SE ended amp)
to refresh, i used the front end circuit described here (http://www.bonavolta.ch/hobby/en/audio/rca.htm) with a two stage line driver (12au7 plate coupled into cathode driver) after it.
The circuit above indicates no grid resistor, but after hearing the advice of the members of this list, i tried various combinations of resistors and grid-plate capacitors.
I first tried 1K grid resistor. It helped, but no enough. Then i tried 330 with a 10pf cap. Again, it worked, but not enough. Then, following the circuit shown here (http://www.bonavolta.ch/hobby/en/audio/dyn_upas.htm) , I tried a 10k resistor with a 10pf cap to plate, and it sure did get rid of the RF, but it also seemed to cut off everything above 12k. So then i backed down the resistor to a CC 3.3k and there it is! worked great.
Overall, my preamp has approx. 1/2 the white noise of the yamaha pre, the channel separation is much better, and the center image is much more focused. There is a slight 60 cycle hum present when the cartridge is lifted off the record, but it is totally subsumed by the surface noise of the LP, so i do not think it will bother me. My lead dress is pretty good, so i imagine that the only way i am going to improve this situation is by using DC filaments, which i do not know how to achieve using the 6.3v AC secondary that I have available.
So, that you all SO much for your help.
Next question: any suggestions for a better phono pre to build?
c/
c/
- Tubes / Valves
- Phono pre amp RF problem
