Old 24th September 2007, 02:07 PM   #1
ncc is offline ncc
Send a message via Yahoo to ncc
Default Please help a newbie with PSU current requirement for Aikido linestage
I'm building an Aikido linestage using all 6SN7 tubes. B+ is 300V and each (half) tube draw about 10ma. I use a PSU that can provide maximum 50ma for both channel.
I'm a newbie in Tube amp and Electronic in general, I have a question: Is my linestage draw 40ma in total or 80ma? If 80ma then I must consider building another PSU, one for each channel
Thanks in advance
Old 24th September 2007, 03:34 PM   #2
jayme is offline jayme  United States
If you are using 350R cathode resistors for both the input and output stages, you are drawing 10mA per tube @ 300V B+.
Thus, you have a current draw of 40mA from the PSU. Your PSU should work fine with this circuit.
Are you using a preconfigured PSU for your Aikido? If so, from where? I'd be interested in possibly picking one up as a test against my homebrew PSU....
how to calculate current requirement chicago_mike Tubes / Valves 9 3rd January 2009 04:13 AM
Aikido 24V tube linestage Sarchi Swap Meet 2 11th October 2007 10:12 PM
Aikido Linestage Project PCB's Geek Swap Meet 2 5th October 2007 07:15 PM
12b4 vs. aikido linestage Klimon Tubes / Valves 2 14th August 2007 11:38 AM
Aikido linestage Help Needed Cambe Tubes / Valves 5 16th March 2007 01:40 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
