Old tube amp
Old tube amp
Old 9th February 2003, 05:52 PM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Old tube amp
Default Re: KT88/6550
Originally posted by fdegrove
If it's just the output tubes you mean then this is intersting to read
So based on their suggestion KT88s... anything suitable other than these? Triodes?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th February 2003, 07:48 PM   #12
Brett is offline Brett
Brett's Avatar
Default Re: Re: KT88/6550
dave
The Dyna OPT is 4300 ohms a-a, so,
300B / 2A3 / 6B4G
Trioded KT88s
EL84 trioded, parallel
and probably a few more when I get some sleep
Old 9th February 2003, 07:57 PM   #13
Per Nielsen is offline Per Nielsen  Denmark
Thanks for the advises!
So the best choice would be the kt88, but there is a couple of manufactors which one is the best? I am thinking on the sound
Old 9th February 2003, 08:01 PM   #14
Brett's Avatar
I like the Svets a lot. NOS KT88s are stupid money for my tastes.
Old 9th February 2003, 08:38 PM   #15
Is there any body who has anoter opinion?
or else it will be the svets
Old 9th February 2003, 09:27 PM   #16
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default KT88
Not me...they're reasonably priced and reliable.
I'd go for them.
Frank
Old 9th February 2003, 09:29 PM   #17
ok!
Old 10th February 2003, 08:54 AM   #18
My first tube amp is working !!!
My Dynacos is now working!!
I have just yoused the night on rewindding the output trafos with copper core, and replaced the gz-34 tubes with dioedes
And it works and sounds fine
But is it healthy for the amps that I youse diodes insteads of the Gz-34's
Can a output tube be to old? the ones im using is more than 20 years!
Old 10th February 2003, 10:59 AM   #19
fdegrove's Avatar
Default DYNA.
Glad to see they're working again.
Most likely the B+ is now somewhat higher than before due to the lower voltage drop of the diodes,you may need to find out what it should be according to the Dyanaco circuit diagram and up the resistor value in the PSU.
It wouldn't hurt to have them checked and replaced if necessary.
Circuit diagram:
UNCLE NED'S.
Frank
Old tube ampHide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 04:19 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 05:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 04:09 AM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 07:47 AM
