I just got a couple of 40 years old Dynaco mark3 tube amps they are pretty smashed up, so i am thinking on restoring them, but the trafos dosent work anymore, so here comes the question anyone how knows were I can get some, I can use instead?
I have also heard that the Dynaco mark 3 is a very good amps, even today! Is that right or is it totally inaudible???and not worth saving? |
#2 |
diyAudio Moderator Emeritus
Per,
Welcome to the forum ![]() Which transformers don't work? How did you test them? Cheers, |
#3 |
Thanks!
The output transformers, the core is broken somewhere in both of them there is no connection on the primary side of the trafos. |
#4 |
Magnequest do reproduction ones from the original blueprints. But they're not cheap and shipping to Europe won't be either.
http://store.yahoo.com/triodeel/magnequest.html Model MQ 431 CL Perhaps someone in Europe could make a replica, or you could get some second hand off ebay. They come up regularly. |
#5 |
Thanks for the advise
#6 |
Which tubes should I youse for the mark 3? KT88 or 6550 and what is the diffrence? Sorry! That might be a stupid question for you guess, but this is my first tube amp!
#7 |
Per,
Brian Sowter will wind some for you: http://www.sowter.co.uk He is always happy to quote. Cheers, |
#8 | |
diyAudio Senior Member
As far as NOS goes you may be able to unearth some NOS 6550s but hardly a decent KT88 GEC. The Dynasours will be happy with either current production KT88 or 6550A. There are more differences between the remaining manufacturers than between the type of tubes nowadays. Cheers,
Frank |
#9 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 | |
COMPARATIVE LISTENING TEST Cheers,
Frank |
| FS tube tuner, Active filter kit, tube amp, amp3 | Josephjcole | Swap Meet | 9 | 20th July 2007 04:05 PM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 03:09 AM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| tube driving the same tube - whats the collective word? | zobsky | Tubes / Valves | 3 | 13th June 2005 06:47 AM |
| Page generated in 0.10176 seconds (100.00% PHP - 0% MySQL) with 9 queries |
