High gain pentodes
High gain pentodes
Old 23rd September 2007, 03:12 AM   #1
AmpKiller66 is offline AmpKiller66  United States
Default High gain pentodes
I have seen this subject come up before, but I have never heard any definite answers, and not for my purposes, anyway. I am designing a guitar amplifier and need a lot of gain. For the input of the amp, I am looking for a small-signal pentode with a ton of gain to eliminate the need for several gain stages. Does anyone here know of such a tube? It would preferably be cheap and widely available. Linearity is not an issue, as distortion is desired.
Thanks in advance,
Matthew
My band Waffle Stomp: http://www.facebook.com/wafflestompband
Old 23rd September 2007, 03:20 AM   #2
Geek is offline Geek
Geek's Avatar
Standard input pentode for guitar amps is an EF86. Though 6EJ7 is catching on too
Cheers!
Old 23rd September 2007, 04:44 AM   #3
Brett is offline Brett
Brett's Avatar
6DJ8 cascoded.
Old 23rd September 2007, 07:32 AM   #4
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Default Re: High gain pentodes
Thanks in advance,
Matthew
I can think of several:
12BY7A -- g(m)= 12mA/V
6AG7 -- g(m)= 11mA/V
These two may or may not be suitable since they like to pull rather big plate currents, being intended for driving CRTs.
6CB6 -- g(m)= 8.0mA/V -- VHF amp. Pretty decent audio characteristics.
6EW6 -- g(m)= 16mA/V -- Another VHF amp.
6JD6 -- g(m)= 14mA/V -- Ditto
6KE8 -- g(m)= 12mA/V (Triode/pentode type -- looks promising for audio)
These types don't require the largeish plate currents of the vid amps, and might be more useful as an audio front end.
Might also want to consider a cascoded dual triode such as the aforementioned 6DJ8, the 6BQ7A, or the 6SN7 (6FQ7 -- 9-pin mini version) all of which work quite well as cascodes. This might even be preferable "up front" since triodes don't have the partition noise problem.
Of course, there are lots more possibilities out there as well.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 23rd September 2007, 10:05 AM   #5
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
Triodes in cascode tend to be much less microphonic than pentodes. Also, pentodes with extreme gain can be problematic in terms of parasitics and instability.
Old 23rd September 2007, 12:48 PM   #6
On Hiatus
SY's Avatar
High gain pentodes
The best, quietest pentode I've worked with is the EF86 and the American variant, 5879. I think they'd do well in this application.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 23rd September 2007, 01:48 PM   #7
Bandersnatch is offline Bandersnatch  United States
hey-Hey!!!,
Pentode gain isn't a tube property, but a combination of tube characteristic, and loading circuit. Gain is about gm*plate load. This is *NOT* advertised gm, but the achieved in-circuit gm. Sooo you need a big load, and high gm. This combination usually requires a fairly high supply voltage. Since we're not going to worry about maximum voltage swing, we don't need to worry so much about the end-of-swing bunching up of the curves; a high load/near hirozontal load line can be employed.
Try a resistor in parallel with a CCS. Drive up the gm with current through the CCS, and get a near-horizontal load line with a big resistor. With this approach, some *VERY* interesting tricks are possible....
cheers,
Douglas
the Tnuctipun will return
Old 23rd September 2007, 05:23 PM   #8
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
The EF94 / 6AU6 seems to be a a very underrated pentode- it's usually much less microphonic than most EF86s. I rate it VERY hightly.
Old 23rd September 2007, 08:46 PM   #9
Geek's Avatar
Some of those pentodes are pretty noisy/microphonic for a V1 position though.... 6CB6 for example, only a few brands are suitable.
But that could be said for most though *shrug*
Old 23rd September 2007, 09:18 PM   #10
Thanks for all of the input. I have some time to kill, so I think I will get several of these tubes and experiment.
High gain pentodesHide this!Advertise here!
Very High-Gain PNP Transistors... EchoWars Solid State 32 29th August 2017 03:52 PM
Beam pentodes and suppressor-grid pentodes of same type jon_010101 Tubes / Valves 3 2nd May 2009 11:18 PM
Outside the box - Low Gain High current Amp EWorkshop1708 Solid State 1 4th June 2008 09:33 PM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
High Gain Preamp amirmk Tubes / Valves 3 27th August 2005 12:00 AM
Copyright ©1999-2017 diyAudio
