diyAudio Sponsor
Old 23rd September 2007, 12:00 AM   #1
dsavitsk's Avatar
Default Tube Matching and Push-Pull
I have a push pull circuit that looks like this:
I have a quad of tubes to use (12J5GT's). They all test good, but they are not quite matched. On my tube tester, one tests 100, two test 115, and the fourth tests 130 (never mind what those numbers might actually mean -- suffice it to say that >80 is "good"). Now, I know the answer is that I should come up with a matched quad, but, absent that possibility, is it better to pair the 115's on one side and the 100 and 130 on the other, or split the difference between sides?
http://www.ecpaudio.com
Old 23rd September 2007, 12:15 AM   #2
SY's Avatar
I'd split the difference.
If you feel ambitious, you could stick a small resistor in the cathodes of the higher gm tubes to try to get them to match the lower gm ones.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 23rd September 2007, 12:25 AM   #3
dsavitsk's Avatar
Sounds like a plan
The fact that these are $3 tubes suggests that I should just buy enough to make a matched set or two. But, thanks for the suggestion in case I ever use something more expensive, or dual, that needs matching.
New design: 12V push-pull tube amplifier engels Tubes / Valves 3 20th September 2007 03:02 PM
Fender push pull amp... using one tube only.. is it dangerous? akimball442 Tubes / Valves 2 3rd March 2007 05:45 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Push Pull Power supply. to Tube or not to? hacknet Tubes / Valves 24 6th May 2004 08:33 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Page generated in 0.07662 seconds (71.52% PHP - 28.48% MySQL) with 10 queries
