I've got a few NOS paper-oil capacitors. Since I don't want to blow up my powertubes I want to test the capacitors before soldering them in. Is there a simple method to measure the leakage current. Thanks Jim |
#2 |
What I do is hook it up to a 1-200V supply with a neon light in series. The rate at which the light flashes as compared to the capacitance is determined by the leakage current.
A typical old, sticky .1uF wax-paper type capacitor might go 1 flash every second, which is approx. equivalent to 2.2megs, IIRC. (You can test that by connecting a resistor in parallel with a good capacitor.) This is safe up to about .5uF, where the pulses start getting dangerous to the light. A 0A3 tube should be used for anything larger. Tim |
| FS: (8) .1uf Cornell Dubilier Paper-in-Oil Capacitors | mrdon | Swap Meet | 4 | 1st February 2008 11:02 AM |
| FS: Paper in Oil Capacitors | ralphs99 | Swap Meet | 2 | 11th March 2007 01:04 PM |
| Paper-in-oil capacitors | chandayot | Parts | 1 | 29th July 2005 06:02 PM |
| testing capacitors | xcortes | Chip Amps | 9 | 30th September 2004 07:21 PM |
| Testing capacitors in circuit. | Tony D. | Parts | 1 | 22nd September 2002 12:14 PM |
| Page generated in 0.21647 seconds (100.00% PHP - 0% MySQL) with 9 queries |
