| diyAudio Sponsor | ||
Any idea about source for buying small qty (for DIYers). of E I laminations of alloy of nickel + silicon steel (50% each) of sizes EI28 to EI57 (American sizes EI375, EI-21, EI-625) for making chokes and output transformers.
Thanks. |
#2 |
Try magmet.com or tempel.com ... Mag metals supplies most of the nickel lams for the audio trafo industry, tempel apparently makes M6 lams.
Also check out the prodigy-pro forums for info. Great bunch of guys over there and they have lots of transformer winding discussion threads to read.
- Chad. |
| I Need Nickel Iron Laminations and Bobbins ! | Nikolas Ojala | Swap Meet | 3 | 7th April 2008 03:57 PM |
| Grain oriented silicon steel core data needed | eppidei | Tubes / Valves | 0 | 14th September 2007 02:08 AM |
| A possible good source for steel chassis | Witchdoctor | Tubes / Valves | 1 | 12th January 2006 04:39 AM |
| source for steel wire | dhenryp | Multi-Way | 6 | 27th January 2004 12:32 AM |
| Page generated in 0.06203 seconds (68.14% PHP - 31.86% MySQL) with 10 queries |
