#21 |
Well the water analogy does make sense, but it still requires some thinking. The concept of equal pressure regardless of pipe thickness makes clear sense as does the conecpt of flow-rate.
Thanks Sy. Charlie |
#22 | |
Thanks SY You DID IT I think we have a first here!!!!! see 2nd line post#1 The B+ Voltage is shared per the tube by each plate. That way the B+voltage is rated at/by the valve spec. sheets and also as rated in John B's table at the end of the USERS GUIDE provided with his PCB kit. Thanks Sy! I'm on my way to brouse around in "The Red Light District" I am very happy to know I was not the only one confused by the Aikido B+ values. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#23 | |
Yes, but I lost EC8010, who is an actual engineer. So forget everything I said, it must be wrong.
EC, if I haven't already, I hereby officially recommend Shive and Weber's "Similarities in Physics." I've thoroughly annoyed my co-workers by modeling diffusion of gases through a barrier with electrical analogies... Quote:
If there's a sucker born every minute, where do the rest of them come from? |
#24 | |
Oh do tell, I love a good story.
#25 |
Trust me, he has a much better story about me.
We were out at an excellent beer bar (Gollem) and started to walk (stagger, really) back to our hotel. A local guy, Erik deBest, was with us. We weren't exactly in the Red Light District, but sort of skirting around the edges. As happens there, a furtive guy with a small brown paper bag comes up to us, goes directly to ME out of the three of us, proffers the bag and asks, "Viagra?"
#26 |
Sy,
No Doubt it was because YOU were the most sober of the three. Cbutterworth, Using the formula for calculating the min. size of the choke needed, I was lucky enough to end up at 6.045. I have read also that using the Fairchild Stealth FREDs will assist in prevention of ringing. Perhaps I should buy a 10H just to be safe. Without spending $$$ on a choke, any recommendations for suppliers? Is there a formula for determining the inductance value (choke size) of a transformer using a DMM? This is a wonderful learning thread !!! THANKS ALL Ron
#27 |
I am using the Hammond 193G, it is 10H. I cannot remember the price, but somewhere around the $30 sounds right. Try looking at the AES website www.tubesandmore.com
They keep many of the Hammonds in stock, although other suppliers such as Digikey can order them for you. As for the FRED, I have no idea if it'll work, but as you already have the 6H choke, why not give it a try, if this choke rings, then maybe invest in a 10H. Keep the forum informed, as we can all benefit from the input. Charlie |
#28 |
Charlie,
Thanks for the link, I'll try the 6H and let the group know what happens. BTW what does ringing sound like? Is that a dumb question? Ron
#29 |
If a choke is "ringing" you likely won't hear it. You'll have a B+ that is not quite stable. It will have some overshoot. Model it in PSUD2 with a slight change (+1mA) in current draw. For a portion of a second after the change, you'll see the B+ swing past the target voltage, then reverse and swing back up, again missing the target. Typical underdamped filter response.
I've had some issues with it in my CLCLC filter. I had two 15H chokes as each L....without HUGE amounts of capacitance, that shows severe ringing. In my case, the ringing showed up as subsonic woofer pumping. |
#30 |
Jayme,
Wow! That's interesting.....I never would have suspected "Ringing" to manifest itself in that way. Do you suspect it was due to the Cap sizing in the filter or the desgn? I do recall reading (but not where), that the first C should be no larger than 8 Ohms, and the last should not be "Huge". Whatever Huge is. Anybody else have different results from "Ringing"? Ron
| Advice for NOOBie - Dad's Scott LK-72 | Vespasian | Tubes / Valves | 26 | 15th June 2008 06:26 PM |
| Newbie Asks: What Gauge Hook Up Wire? | JimOfOakCreek | Parts | 3 | 8th July 2007 04:02 AM |
| newbie asks question :cathode biasing | garbage | Tubes / Valves | 9 | 17th April 2007 09:20 AM |
| Reclocking CDPro, TubeDac and I2S, Newbie asks questions! | Rupert Austin | Digital Source | 23 | 29th June 2004 08:29 AM |
| Another Newbie asks: How do I build the crossover? | steelyjoe | Multi-Way | 4 | 30th November 2002 02:49 PM |
