diyAudio Sponsor
Old 17th September 2007, 02:53 AM   #1
Rob11966's Avatar
Default Earth Bus Wire - Where can I get it?
This is a fairly mundane question unfortunately.
I am trying to get hold of solid copper, nickel plated earth bus wire. On my last project, I was lucky enough to find some at work but that source has now dried up.
I have looked at most of the antique on-line tube shops that I know and have checked ebay on several occasions - no luck. Farnell does not seem to supply it. RS appears to stock 14awg tinned, copper wire but it is only available in 30m rolls at a cost of about $190!!
Does anyone out there have a secret supplier?
Thanks in advance,
Rob
Old 17th September 2007, 03:16 AM   #2
SY's Avatar
Why nickel plated?
Plain copper works well. I cut up 3 conductor solid wire meant for house mains wiring. It's easily available to 10 gauge and costs very little.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 17th September 2007, 06:26 AM   #3
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
mouser lists belden 14GA bus wire, $67 / 100', which is still too damn much I'd say... but better than your $190 quote.
http://www.mouser.com/search/refine.aspx?Ntt=566-8012
Old 17th September 2007, 06:52 AM   #4
chrish is offline chrish  Australia
chrish's Avatar
I have had difficulty in finding solid core wire locally too. Can get 1mm solid core at the local hardware store, maybe a bit too thick for heater wire (but I have used it for this) and perhaps a bit thin for ground bus wire. Used to go to the USA a bit with work a while ago and still have a few metres of the wire that Sy described lying around with a 2mm solid copper ground wire. If you are having difficulty sourcing something let me know and I can pop some in the post for you. Where in Sydney are you? I am Mittagong but travel to Bondi fairly regularly.
Cheers
Old 17th September 2007, 07:04 AM   #5
Geek's Avatar
100' roll of house wire is what, $50-60? $30 on a "door crasher"... There's 300' of 14GA copper for one right there
Old 17th September 2007, 10:57 AM   #6
nkg is offline nkg  Australia
Hi Rob11966
I live in Perth WA I have some 3mm copper wire from some high tension cables at work
if your interested I can send soe if you wish.
Nigel
Old 17th September 2007, 12:45 PM   #7
Rob11966's Avatar
Hi Nigel and Chrish,
Thanks for the offers, I was not expecting offers but certainly delighted to consider. Nigel, I think that the 3mm may be a bit thick for my amps (maybe not but that is one thick wire) - if I can get something a bit thinner I might go for that but thanks for your very generous offer. Chrish, if you are not going to use your wire, I would certainly be interested but only if it is not going to be used. I live in Randwick, so not so far away at all. If you think you are going to need it though, hang on to it, I am sure that I can source some copper wire from a power cable - I was fixated with the nickel plated wire but it is now clear to me that plain copper will do just as well. If you are happy to part with it then I am certainly interested, drop me an email if you like.
Thanks,
Rob
Old 17th September 2007, 12:59 PM   #8
chrish's Avatar
G'Day Rob. The wire I have was from when I had the crazy idea of wiring up my garage dual voltage with 120/240 volt so I could get cheaper power tools from USA when I was flying there a lot with work. Decided against going that way so have a pile of wire left over. I guess that you will only need about a metre or so, that is not a problem. You don't have email turned on with this forum (I don't think I do either). You can contact me at h e a d m a s t e r ( d o t ) t h e ( a t ) g m a i l ( d o t ) c o m . I am in the middle of a university assignment at the moment and may get called away with work (work has me travelling away a fair bit) so if you are not in a desperate rush I could either post or drop off on my way through to Bondi.
Chris
Old 17th September 2007, 02:04 PM   #9
Hi Rob
With thicker the wire the less volt drop you will get and less inductance. It also has the advantage of being mechanically quite strong for hanging components off it.
Nigel
Old 18th September 2007, 04:40 AM   #10
Rob11966's Avatar
Hi Nigel,
I have never really considered such thick wire but you make a good point. Chris has also very kindly offered to send me some wire and he is a lot closer and I don't need that much. Can I contact later if required? In the meantime, I watched that West Coast game - tight game and you guys were unlucky but fantastic game.
Rob
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
magnet wire (not sure of the term) used as chassis wire? jarthel Parts 8 27th September 2006 09:50 PM
How to wire a Ixos Gamma 7 bi-wire cable mangalchacha Multi-Way 1 13th April 2005 02:58 PM
Earth wire in a Rega arm sreten Analogue Source 0 6th December 2003 07:25 PM
Page generated in 0.10827 seconds (79.39% PHP - 20.61% MySQL) with 10 queries
