diyAudio Sponsor
Old 16th September 2007, 08:23 PM   #1
neazoi is offline neazoi  Greece
Default 45 amplifier
Hi I am looking for an amplifier schematic in class A1 using 6sn7 and 45 tubes.
I am interested in Single Ended topology or Parallel Single Ended.
Please post anything you have got,
Thank you very much.
Great DIY site: http://www.neazoi.com
Old 16th September 2007, 09:47 PM   #2
kmtang is offline kmtang  Canada
kmtang's Avatar
Default Sun Audio 2A3
You may use the Sun Audio's 2A3 schematic for use with the 45 tube with only modification of the cathode resistor from 750 ohm to 1.5K. It employs 6SN7-6SN7-2A3.
I trimmed the B+ to approx 310Vdc with double LCLC B+ filter. It sounds very nice indeed.
Johnny
Old 17th September 2007, 05:42 AM   #3
Thank you.
But I cannot find the schematic anywhere... ??
Old 17th September 2007, 05:38 PM   #4
Default 45 Amp
I built the project outlined in Glass Audio magazine (3/95).
"Single ended glory for under $100" by Eric Barbour.
His cost assumes a well stocked "junk box". It cost me about $400.
Mr Barbour is a tube circuit designer for Svetlana tubes.
His 45 amp uses 6sn7 input, is simple and sounds fantastic in my opinion.
mg16
Old 18th September 2007, 06:03 AM   #5
Thank you all for your replies!
The thing is that I need a schematic and maby some notes about the transformer for both single ended and parallel single ended...
Because I do not have these magazine issues..
anyone please?
Old 18th September 2007, 04:09 PM   #6
Default how about the bugle??
Here is a link to an article by the designer about how he put together a 45 amp.
Gordon Rankin's Bugle
"Give me the Luxuries of life & I will gladly live without the Necessities" (Frank Lloyd Wright)
Old 18th September 2007, 08:02 PM   #7
Ok, that sounds like a good deal.
How about this one?
http://members.myactv.net/~je2a3/simple45.htm
Is it worth it?
It seems a quite easy to build design...
If more gain needed I could use another 6sl7 to add a third stage.
Could an 6sn7 be used?
Any other schematics?
Old 18th September 2007, 09:33 PM   #8
MartinV56's Avatar
Hi, view this circuits
Sun Audio
JE Labs
Old 18th September 2007, 09:34 PM   #9
MartinV56's Avatar
JE Labs
Old 19th September 2007, 06:00 AM   #10
Thank you for the circuits.
As far qas I can see not many differences to each other.
Relatively simple signal path and psu. Easy to construct despite of the costly tubes and transformers..
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Page generated in 0.09959 seconds (74.99% PHP - 25.01% MySQL) with 11 queries
